Mugabetown - Whoretownin' At It's Worst.
In other news... Swapped some 2871's into a mates zed over the weekend. What a PITA.
Goes pretty decent tho, considering 14psi and a stock engine with low comp on at least 1 cyl :D
I found them quite good also :s
For the price
They're decent in the dry, but absolute rubbish in the wet. As quite a few at the sprint day last year will attest to :P.
If you think they're 'quite good' in the wet, you need to try some other tyres ;)
Ohhhhhhh I didn't realise they were designed to be a wet track tyre! :P
Kuhmos FTW!
For real though 595s are never going to be excellent in the wet, they have no radial grooves, The EVO or the RPM are needed for that. Trouble with either of those is the crappy size selection though, Luckily I can fit a 285 if I really must.
Edited by Bunta
I wasn't using them at the track... but others were and found them to be quite useless.
I have used them on the road before though and they were terrible in the wet. This pair I just found in my garage, I think I bought them second hand from Pete. They are equally awful.
You are right they are never going to be good in the wet due to their tread pattern. Just can't figure out why people keep buying them and claiming they are god's gift of cheap tyres when they are so, so bad in the wet :S.
Guess the kiddies just love their liquid horsepower and don't know how much better it is to have tyres that actually provide some traction in the wet
You are right they are never going to be good in the wet due to their tread pattern. Just can't figure out why people keep buying them and claiming they are rajab's gift of cheap tyres when they are so, so bad in the wet :S.
They get most of thier props from the drift community dont they? and for that they are especially good, can take a real beating
Because it almost never rains?
    • 16 years later bump. Are you still doing the elec work?
    • Ugh shit, sorry to hear that, hopefully its a smooth and easy process to get the old one back in.
    • Yeah i thought so too...but iam kinda confused what is what and what to get to make it work. I know i need a push clutch(i get that with that kit i post)  It has flywheel too and from what i found it should "mate" with RB25DET NEO. But i dont rly know about the bolt count cuz i saw many videos about clutch on RB25DET/NEO and all of them has 6 bolt pattern... Like here for example... And if i google clutch kit for RB25DET NEO like "all of them" has 6 bolt flywheel...
    • From memory when the tank is full is when the resistance from the fuel sender reads its absolute lowest. It sounds like the short has made its way to the fuel sender wires... Which also means the short could possibly be in / around the cluster.
    • Actually, that's what that post is saying is happening, with only the LAST 10mm to the wastegate flange not divided. A whole single centimetre is what they're claiming caused that change. However, I haven't actually punched the numbers in etc to do any mafs, but they're talking 26PSi + of boost, and it taking nearly 2 seconds longer to climb a further 200rpm... Yep, it was in 4th gear, but, say that car does 2800RPM at 100km/h, they're talking a car making 26PSi, is taking an additional nearly 2 seconds to go from 128km/h, to 135km/h... That's pretty extreme to me. Also interesting as you scroll down through the comments and I started reading there was someone who's done very similar testing, on a hub dyno, back to back without even pulling car off the hub dyno, and barely saw any change what so ever on a stupid powered car.
