Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
so trailer booked, address in hand, and revs cheack all good :)
getting the body tomorrow and then let the swapping begin!!
schweeeeettt!
All i see is a car idling, not being driven.
patience is a virtue Grego.
You will see it in action soon enough.
Or alternatively come down the GC tomorrow and see me drive it :)
Evening all!
They're decent in the dry, but absolute rubbish in the wet. As quite a few at the sprint day last year will attest to :P.
If you think they're 'quite good' in the wet, you need to try some other tyres ;)
I assume you speak of the 595SS......they are useless. Pete, it always rains when I want to go for a nice drive....stupid weather.
I've never had nice tires on my car ever... Maybe one day
skids
Live to bake?
this
Kuhmos FTW!
agreed, and lifespan is much better too
I wasn't using them at the track... but others were and found them to be quite useless.
I have used them on the road before though and they were terrible in the wet. This pair I just found in my garage, I think I bought them second hand from Pete. They are equally awful.
You are right they are never going to be good in the wet due to their tread pattern. Just can't figure out why people keep buying them and claiming they are rajab's gift of cheap tyres when they are so, so bad in the wet :S.
Guess the kiddies just love their liquid horsepower and don't know how much better it is to have tyres that actually provide some traction in the wet
they do break traction pretty easily too....Sic skids, but mine left very little marks on the road...skid fail :(
get into it!
Commo spec?
LS7?
good chat :P
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
