Mugabetown - Whoretownin' At It's Worst.
So problem number one............
There is a knocking noise from the rear when I brake or put the car in reverse. The best way I can describe is like backlash from within rear driveline, a bit like a weight being pushed forwards then going backwards. Its not a harsh noise.
I have had this problem ever since I have owned the car.
It does not happen all the the time but I would like to get rid of this pesky issue.
Im thinking the rear diff is the culprit.
Anyone have any thoughts?
How olds the diff, could be getting play in it and you're hearing the slop as it goes from forward to reverse and back again
I don't know about Cusco.
What I do know is that most 1.5 / 2 way jap diff tend to be a bit tough and clunky (friction plates)
With helical there is none of that and therefore is just smoother and runs quieter
Diffs are a bridge i'll have to cross at some point soon-ish i think.
You'll have to re get your exemption won't you?
Also, I have a hard decision to make. GC hinterland or Mt Nebo
Up tambo, down tambo, up Oreilleys... ah f**k this roadworks and the 1 lane road, back down Oreilleys, up tambo, down tambo...
Stopped in at Cedar creek on the way back down too, i think i'll have to bring boardies and a towel next time.
If I had today off I would come with you Pete
I'm not sure my car's good enough to be seen with yours (once you get it finished at least!)
probably one of the most underated mods you could do IMO.
Will do front one too after my bank account recovers.
Zac will be busy.
Well she is kinda finished. I'm even taking it with me to work FTM.
Just need to respray rear bar.
My car would be fine with yours or any other Nissan. Just no commodores
    • Best practice for any track day should be Bleed brake fluid, inspect rotors and pads maybe even flip pads if they are prone to tapering.  Quality pad (project mu, endless, hawk, winmax, ap), Good high carbon content rotor (dba4000/5000, Ap, projectmu), Quality fluid, Good air supply over the rotor and caliper are all required for best performance at a track day no matter the car.  Even the bedding in of the pad and rotor is key to longevity. I've seen so many rotors destroyed on their first track day due to it.
    • The hardcore tracks1ut guys I know would flush their brake fluid every 6 to 12 months depending on the amount of track work they did. Unlike most of us SAU guys, probably flush it once a decade 🥲
    • Now that these are NLA, I suspect the answer is going to be to 3D print the plastic bit and glue on some felt or something to replace the brush. I have one or two of them (new) in the shed to go onto the car at some point. I could put some effort into measuring them up and could attempt to draw up the printed part in FreeCAD, if there is interest.
    • Hey team, the R32 ones look different to the R33 and 200SX ones. Also they're sold out on Amayama, looks like some dealer cleaned up the stock.
    • Might have to @Dose Pipe Sutututu him
