Mugabetown - Whoretownin' At It's Worst.
t5iv
 Share
For your sake you would hope he only has 1, otherwise you will end up with a backyard full of R31's :P
don't you own an R31 Grego?
Nah, its the awesome TV show where a scientifically engineered invisible man works for the department of fish and game.
am lost
Trying creatine.... Loading day 1 lol
ohh hell no. You will look like TMNT morphed up.
You really don't need to have to lift more or get bigger
that sounds terrible, i think i'd want to be half cut for that.
It's pretty easy to get hurt if you are not careful. In any case I a no longer on call in 27 minutes. Good times!
Have had the little gym nut brothers living with me for the last three weeks. Pre mapped out 4 day a week workouts aswell as no shit food in the house and all the supplements and chemicals I can pump into my body.
#@tmnt
#MINIHULK
#@tmnt
#MINIHULK
lol @ minihulk
#@tmnt
#MINIHULK
So Nick's on the gear?
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
