Mugabetown - Whoretownin' At It's Worst.
A 20k 33gtr with 40k spent on it would be better than a 400r anyway
It would just be a r33 with 40k spent on it, one of around 40,000 cars, a 400R, while it wouldn't perform at the same level, is a 400R. Owning something most people have never even laid eyes on in the flesh would be pretty cool from my point of view.
my name is Ants and I support this ^ statement
Yup. Definitely.
*Sigh* There is a set of LM GT1s for sale, I want them really bad, but my monies are yet to hit my account, so that would mean selling my wheels first #firstworldwhitecarguyproblems
The ones in the Classifieds are cool
credit card?
Yeah they are sweet, I have been looking for a while and these are by far the best condition I have seen
credit card?
I have a small emergencies only one, I don't think the limit is even high enough to buy the wheels!
:O
well, a 20k gtr with 40k on it is bespoke, so technically it is that. Horses for courses i suppose though
The point I am making is that I really dont give a shit about another R33 GTR, 40K spent or not, as its just another thing I have seen 30 times before with no historical significance, that any one can just go out and build. A 400R is something I have never seen before with my own eyes, is the first of the factory specials to use the 2.8 and is significant in the GTR story, and you cant just go build one, you need to wait until one comes up for sale.
Oh and generally I don't get excited about 'special' editions like Vspec R32s ect and would have the same opinion as you Pete, but none of them are as different from the original item as a 400R is.
or the Z-tune
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
