Mugabetown - Whoretownin' At It's Worst.
Ah ic... easy as then ;)
Yeah it should be. I've already filled out the form including majority of the 'office use only' section lol
they should pay me to do it.
This is probably something i should do too... Car has only been back on the road for 6 months
Not a bad idea Scottie considering QMR and QPS like to make sure the engine number matches to their records................oh and the fact that the maximum penalty for not advising them of this can exceed $6,000 :woot:
So merely chump change then lol
Can also request a 'donor' engine number from them, in the case of blocks being skimmed so as the number is no longer visible etc.
All you need to do in such case is fill in the form and list reason as 'engine block decked' and provide evidence (receipt for such decking or similar).
Who wants e85 and p100 discount vouchers!!!
I have some here for united with a 5c a liter off and they expire tomorrow
Each voucher says max of 100liters
They also have a free can of Pepsi with them
I have 2 for grabs
Just gotta swing past and grab them
Text me on 0432799909
awww too late, and no car that needs em :(
afternoon all, weekend of no internets should have been good for car work.......but instead spent fixing internets. how many modems do I need to buy in my lifetime?
shit Bodo. I've only ever had one modem and it's done it's job.
Although you probably ass rape your download limits compared to mine which would explain why you go through so many modems
Aye, having a radiator is a good thing.
I always had one just thought that since im making 600rwhp+ its about time i upgraded from the standard one
nice. You coming to Easter cruise?
Ps I know your workin but a sickie will help :D
Unfortunately no chance of a sickie. New radiator post in build thread needs your attention Ants lol
that sux Scottie. Will have to be another time
Build thread replied to
You never disappoint Ants!
Currently having trouble with re locating the Oil Filter. Trying to avoid doing the whole thing again. Damn the workshop mounting it on the fan shroud, where it now doesnt fit
so you are trying to relocate the oil filter again?
Yes. When the young apprentice did it, he mounted it on the side of the fan shroud. Whilst outting the radiator and shroud back on the screw came loose. To put it back in that location I would have to take the filter off the plate and thus spil some oil. Trying to relocate it to an easier location. Trying to get it to replace the washer bottle spot. But the lines arent playing nice
that will be subject to trial and error Scottie.
As depending on the length of the lines will determine your new location.
My oil filter relocation kit is mounted under the car next to the sump.
Best mod ever. As all the oil expels down naturally after you remove the oil filter (thanks to gravity) and makes minimal mess
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
