Mugabetown - Whoretownin' At It's Worst.
Yeh mate, over 7 years now :wacko:
Aiming to get out asap but GT-R's are so damn addictive!!
Lol! Ants is an accountant as well. I'm an accounting recruiter. This busy season seems to be absurd. Can't catch up with mates or anything! Everyone is really flat out. Think the short April hurt. Are you in practice or commerce?
Nice one! Did you see what happened to Liverpool?
I did Tony, I laughed quite hard and also gave shit to all my Scouse supporting mates.
Just spoke with EFI and car should be on the dyno this afternoon
Our boss is a dirty scouser and I gave him a lot of shit. I'm a West ham supporter so it should be interesting to see how they go against City.
Swapping to an MTA as well?
TBH honest, Liverpool lost the title race the moment Gerrard slipped on a banana peel. The draw with Palace just means they wont lose on goal difference.
My Precision has so far performed faultlessly, I truely think Noel got a dud unfortunately. EFI struggled to get 600 out of it and shortly after it seized up and was useless. Mines run perfect on 512hp and on 588hp. Time will tell if they can get over 600 with it. New 2200cc injectors, 100mm intercooler & new external fuel system will surely net me at least a 12hp upgrade right? Unless it blows up
Nice. Should perform well I reckon 650hpatw ;)
you know me and numbers...............we hate each other lol
I reckon the setup does have 700hp in it... but ill be happy with anything between 600-650 for now. Can always push the limits later on
Time will tell my friend. Always exciting to hear the performance of other members cars being tuned :yes:
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
