Mugabetown - Whoretownin' At It's Worst.
Sorted, grandma is goin to do it
Exemption is not sorted and this isn't working towards it, this is because I'm sick of having a car there doing nothing and can't take it anywhere. This way I can still take it to places for work to be done and drive it for work, and still attend event if someone will take it
But there is another work around with the exemption I'm going to give a go. If it fails. Then it is there untill opens but will be driven more
Now to buy a solar trickle charger
  • Like 1
How long until you get your opens?
I was wondering why that minor thing would stop you from fixing and entering, but of course, engine out
lawl smartass :P
Usually a battery out job at least, but since mine is in the boot it should be easy enough.
Also starting the twin 2.5inch intake piping upgrade, and plenum pull also for 1000cc injectorz. Can't finish that until I get plenum gasket from the US. $20 gasket. $85 shipping FML
Exhaust staying the same, already twin 3inch.
Currently running single z32 maf (which is pretty much at its limit at 5V) and stock 2inch (x2) intake piping. So going twin maf and 2.5inch intake piping upgrade which should reduce restriction pretty well. 500hp on nismo 555's basically maxed out also, kill the 2 known limiting factors in 1 go.
I suspect next limiting factor will be tyres and driver haha
lawl smartass :P
farkin lul....at shipping cost
why driver?
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
