Mugabetown - Whoretownin' At It's Worst.
Eating at your desk is bad for your health, your moral and your productivity. Just sayin'
Also, a call for help to all my fellow whores! http://www.skylinesaustralia.com/forums/topic/431683-request-for-photos-and-video-from-ths-year/
Why?
Long story short not having a proper period of downtime at lunch increases stress significantly and doesn't give you a chance to recharge. As a result you are less likely to be as creative, as productive, as happy or as healthy in the long run and your work output and quality declines both in the short and long run.
There is a decent amount of scientific research in the area, I can dig some up for you when I'm not so swamped with other research assignments if you'd like. I used a chunk of research into the area when preparing a workshop last year on why stress management needs more attention in business. In terms of directly linked stress issues that can actually be measured, work related stress accounts for losses to developed economies of approximately 2.1-3.6% of GDP. Why add to that figure by not taking 30 minutes away from your desk to unwind at lunch?
If HR guys like me can save big chunks of money I'm all for it :) Stress related work absences cost the US Economy $300 BILLION a year.
I'd be willing to bet most of that stress comes from low wages and high expectations of employees...USA for ya.
Problem i have with the 30mins lunch break is if i drive to subway to get lunch, by the time i get back it's 28mins gone, takes, so naturally im eating at my desk anyway, and i wouldn't call those 28mins i spent driving to subway and waiting for food "relaxation".
But it certainly is nice to be uncontactable for 30mins at that time.
That would mean I have to socialize with other humans
I might have some footage from start of year boz
Unicorn washed. I am going to need to paint it in the next 12 months of I keep it. The white is falling off all over the place revealing the gun metal goodness below.
Custom gunmetal flecks? :P
Pretty much. Who ever did it did a shit job. The gun metal is still all shiny.
Bought a reconditioned CAS from USA it arrived today :D
Went to work sick rather than having day off cause I wouldn't be resting at home.
Also A/C tensioner bearing turned up :D
Good stuff. ..CAS's are the devil!
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
