Mugabetown - Whoretownin' At It's Worst.
So all the trouble of boring out a 20 block to fit a 25 head for what?
Its still a 20 head just with a 26 crank and SR20 rods from what I remember of them. The bores are way different 20 vs 25 they're like 80mm in the 20 and 86 in the 25 lol.
So a stroked 20 essentially? Still a dirty 20 then Martin.
Yep essentially that. So you still have to deal with the shit head on the 20.
I can understand the point of it if you want to run in a class that requires original engine, makes sense but you could probably go just as well spending the money on a good turbo set up for it etc.
Run the pinny in street class instead?
That's what I thought, few decent bolt-ons and you're good to go.
That would require registering it with a full weld in cage.
why dafaq you wanna do that???
May as well just put a 26 in it
Bit more capacity, not going to cost that much more than rebuilding a 25 bottom end, I can still use all my bolt ons, etc.
26 into a 31 is a multi million dollar excersize, and I'd basically have to start from scratch. Why the f*ck would I want to do that?
Why? a 60 with hydraulic lifters. I still say 25/30.
See above.
25/30 is a possible option but will probably need a bigger turbo.
Put down the crack pipe and just get a 26?
See above.
If thats the case I'd just stick with getting another 25 into it. extra money spent on the 26 crank would be better spent on tyres and entry fees.
The difference between the two is only 70cc anyway i doubt it will make that much difference
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
    • You just say that the premium increase seems particularly excessive (no pun intended) and that the value decrease seems unwarranted. You say that it's not 2005 any more, and that these days Skylines are generally owned and insured only by those that have demonstrated an ability to keep them in one piece across decades, and are therefore not the horrible risk that used to be assumed. etc.
    • Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
