Mugabetown - Whoretownin' At It's Worst.
If you can convince the company that they need you and couldn't operate profitably without you, you have a winning argument. Hence $20k raise at the beginning of the year. ;-)
that is very rare, as it is seldom that one person could have such an impact on a business. Especially in the resources sector
If I amended that to 'as proftiably' would that be a more correct reflection? Of course, for this to occur, you would need to be at the top or very close to the top - especially within an arm of the business that closely related to sales.
it truly depends on the demographics of the business
Yes, if key senior personnel ie executives were to use their position as a bargaining chip to demand an increase in their remuneration package then it may work
Should it he reporting entity though - them auditors would be all over it
Especially the way the public now eyes deeply what how execs are remunerated
In a smaller sized business ie SME - most that are in a top position usually have the ability to influence everyone - making performance bonuses that much easier ;)
  • Like 1
Jawsome!
do tell how!
I was curious too so I did a little digging on the QLD/TMR site and I found this:
Moderately-Powered Vehicle Grounds
You may apply for a certifi cate of exemption if the car you wish to
drive was manufactured before 1 January 2010 and has:
• a supercharged or turbocharged engine, not diesel powered
• a power-to-weight ratio of not more than 125kW/tonne
• no other features of a HPV listed on this form.
You application must be supported by:
• a document published by the manufacturer verifying the
power-to-weight ratio, such as the owner’s manual or
information from the manufacturer’s website; or
• a specifi cation information test report.
A specifi cation information test report is issued by an automotive
service provider and must show:
• the name and address of the organisation(s) that conducted the
test(s)
• the date of the test(s)
• vehicle make, model, VIN/chassis number
• the vehicle’s kerb weight and maximum engine power
• details about the measuring system used to conduct the test,
for example, an engine dynamometer."
From what I've been able to find a stock 33 gts-t would have around 130ish kw/t if you're going off the factory engine and weight figures from nissan. That power to weight ratio wouldn't classify for an exemption however if you were to put the car on a weigh bridge and run it on a dyno it would most likely be under 125kw/t though. So I guess it's all up to which figures they take into account when doing the exemption.
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
