Mugabetown - Whoretownin' At It's Worst.
20 Boosts Mike.
At the end of the day the turbos would probably like more, but i don't want to drop the valve spring money, and then might as well do cams... and cam gears, etc.
also, made a map of united E85 locations in-case anyone's interested. Supposedly they're opening one in Ipswich soon to.
  • Like 1
20 Boosts Mike.
Hey Pete,
is your r tuned on Unicorn blood?
Indeed, whole point of the tuning exercise!
Took it for a quick drive up the moutain, feels a whole lot more powerful. Will have to plot it in excel or something to compare it to the old graph.
These results are really making me question what the helll my turbos actually are. 2510s shouldnt make a smidge more power than Petes on 6psi less and on 98.
How much did you pick up from the E85 Pete?
Do suspension, then do E85 but with a flex sensor later
Wise words of wisdom from sir Andy
that is what I was thinking also
I could have afforded both actually but I have been on spending spree of late and ze credit card has to come to nil to keep my levels of satisfication steady - so something has to take a back seat.
I'm keen to also see the comparison
I totally get that, I go to spend on the car car then go naahhhhh I would be happier WITH the money lol
2510's def should not be anywhere near 300kw at 14psi
That's a unique perspective... I don't get it...
I once was unlike that too, I guess it comes from being an old bastard!
Yeah, I suspect when they were overhauled they copped a high flowing also. I usually see 300rwkw at 20psi or more from others using 2510s. I was never able to run any timing either. Will be interesting to see what they are really capable of. Edited by Bunta
if that's the case those turbos are going to be EPIC to say the least
40hp, with 4psi more. but limited by the valve springs.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
