Mugabetown - Whoretownin' At It's Worst.
This is true, should really head home and prepare for my 9:30 footy game.
smart move.
I'm also off to get some rest as this cold is fking me around and I have my fathers bday tomorrow so will have some scotch then
I didn't have hangover food because no hangover... But I did rage at pancake manor and get discount on foods! Took an hour to get our food this morning holy shhhiiiitttt!!!
Then came home and washed two cars and I have to work tonight... Waaaaaaaaaaaaa for working on weekends!!!
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
    • Update from today; Hard work was completed today behind a computer... Ha ha Hardlines for new fuel lines ordered, and fittings for it to connect up too. Banjo fittings for owner steer ordered too, will be AN fittings. Ordered all the weld on fittings I need to build the PS reservoir too. Only things I'll need left for power steer is a couple of off the shelf fittings for the pump, and to build 3 lines.
