hi guys, about to start a single conversion on my R34 GTR and looking to offload some left over parts i will have.
all the parts are currently still fitted to the car and in running order. At the moment im getting expressions of interest so when i pull the car down in approx 1-2 weeks i will have interested parties (hopefully).
CES Racing split dump and y-pipe combo to suit NISSAN GTR R32, R33 & R34.
“COMPETITION” model - LONGER IN DESIGN WITH DEDICATED "Y" PIECE. Dump pipes are ceramic coated mild steel and y pipe is stainless and uncoated $800
Nissan R34 GTR v-spec factory turbos including all oil and water lines up to the firewall junction . Currently running on the car and in good condition. $400 neg
Nissan R34 GTR factory air box with K&N panel filter $250 neg
Nissan R34 GTR factory rubber ducting from the afm to the turbos $50 neg?
Nissan R34 GTR factory air flow meters x2 $150 neg
Nissan R34 GTR factory intercooler hot side Y pipe (twin turbo pipe) $50
all parts are located in Townsville and will be plus freight for anything needing to be sent.
thanks adam
https://www.sau.com.au/forums/topic/431258-r34-gtr-parts/
Sorry to stuff people around. There has been a slight delay in fitting up the new turbo kit and it has in turn delayed when the parts will be ready for sale. As it stands now the parts will be ready for sale from the 14th October. Pics will be up then too as all will have been removed from the car. I apologize again to those that have contacted me and were told of the delay but it was unfortunately unavoidable.
https://www.sau.com.au/forums/topic/431258-r34-gtr-parts/#findComment-7026907
  • 4 weeks later...
Finally all ready to go. Pics below.
note the turbos no longer come with any of the water and oil lines as some of them were... lets say "damaged" in the removal process.
Edited by drag-on silvia
https://www.sau.com.au/forums/topic/431258-r34-gtr-parts/#findComment-7067329
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
