Rb25Det R32 Melbourne
For sale: reliable turn key drift/street car. R32 reg till April. 25det freshened up all new gaskets including 3 layer metal cometic head gasket. Freshly recod 25 box work all carried out at forced motorworx. Custom 1 piece tail shaft (professianly made) brand new excedy 5 puk heavy heavy heavy duty clutch with fresh machined fly wheel. Front mount hybrid cooler. weldy, good condition hsd coilovers all round. Gtr front brakes. Jdi street knuckles with 33 lcas. Fenix 52mm rad. Jdi extended rear arms to correct camber/toe. Full interior, Cams bolt in half cage. 17x9 +5 work stitch i think up front with new n6000s, work rezak rears 18x10 +24 with 25mm metal flared guards. Gtr copy fibre glass bar (cracked) type m skirts car is satin black (2pac not rattle canned) standard turbo, standard boost. Brand new oem coil packs. Brand new alt and power steering belts. Have a bunch of spares like arms and panels that can go with it. Selling because im geniually just over it and want a 4wd. Have spent a fair bit getting all driveline freshened up for reliability. Bad points: dump pipe is welded to turbo i have a stainless split dump to go with the car and i can organise another turbo.the bracket for the top pipe of the cooler piping snapped so its zip tied up. Can organise roady if need be. 8k or 7k no wheels. 0430505810. Can send photos via text
 Share
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
