Simon, I have an iPhone 5 and I am not able to do bluetooth streaming via this handset to my V36 350GT SP.
Chris Rogers has informed us that the technology is different and it wont work.
handsets like the samsung g2 and Nokia windows handsets work fine and have been confirmed by others.
I haven't seen anyone with an iPhone 5 get it to work, apparently the iPhone3 worked well and don't know about the 4 or 4s.
I use the Apple Composite AV cable with a lightning adaptor to connect to the iPhone 5. NO VIDEO SUPPORT just audio.
http://store.apple.com/au/product/MC748ZM/A/apple-composite-av-cable?fnode=45
I have tested a iPhone 4s using this cable and can get the video to work a treat but the moment the car isn't in park you wont have video only audio. You need to do some sort of video bypass thinggy that i haven't the stones to do as im not confident about pulling out the dash!
I can only tell you what I have done to my v36, and what i have got to work for me.
Yes there has been numerous posts about this however nothing really definite to say this model phone works and this one doesn't.
I have NOT got the iPhone 5 to work unless I am missing something i really DONT think this handset will work with bluetooth audio streaming.
There are a few post confirming that the iPhone 5 works. It works on my car. I have tested iPhone 3, 3S, 4, 4S and 5 on mine. All works well, no issues whatsoever.
What I do is I connect the car and phone via BT through the phone function of the car
And then turn on streaming through the music settings where you adjust bass, treble, increase volume while driving, etc...theres a menu for bluetooth streaming music in that
Check the translation pdf file pinned on the main V forum page. PM me if you need more details. I cant remember exactly now that I'm at work but can go thru with you later when I get in my car or at home.
Wow thanks Colin, I have my iPhone 5 working via bluetooth for phone functionality olny however Bluetooth audio streaming I haven't been able to achieve this.
I will review the translation pdf file again an let you know how i get on tonight.
I will look under the music settings menu and respond.
for some reason i thought BT audio streaming didn't work under this car and just lived with that.
Nah it works fine mate. Lazy bugger like me can't be stuffed burning CDs.
Alternatively use the CF card slot...works great too...but limited amounts as well IIRC
BTW mines a 2007 V36 Sedan
There is an option under the bluetooth menu where you will see all other phones that were paired with the car, delete them all, then pair your phone again and you will see a sub menu where you will see your phone that is paired and if you click on it, you highlight a button on the far right of your handset and then the bluetooth streaming will start working, i was also under the assumption that new phone with newer BT software dont work but it is not the case so far every phone i have tried has worked if you follow this procedure.
cheers
Ok I have to be a total spaz because I can't get this to work.
I have removed my device then re added it and I can't see any Bluetooth streaming options.
I have check the sound settings menu where the base and fader are and the was no options.
If you could spell out how to do this that would be great.
thanks guys!! just got it to work :D i sort of followed the pdf directions and played around on it a little and thats about it.
heres the pdf if anyone needs it: http://www.skyline-gt.com/forums/index.php?app=core&module=attach&section=attach&attach_id=299636
  • 3 years later...
Hello guys. I got my phone to pair up, but it saying it only for call adiuo only and I'm interested in stream my music. Any help would be appreciated.
Thanks in advance
You can have just call audio or just music or both. you need to choose the right one in the settings when pairing.
pair agian and try a different option. (I'm guessing yours is still in Japanese)
Thanks 20161206_220707.thumb.jpeg.8291ae52e8698mate. Do you remember what's for music as I just repaired using all and all saying call audio. 20161206_220724.thumb.jpeg.0b68557dadaa820161206_220716.thumb.jpeg.ed547a538bc6a
My navigation through the menu is different from yours. For bluetooth I have to enter the phone settings first. I'm wondering if because it's paired in the phone settings would be why I can't see a bluetooth option under audio. Hmm.
download the google translate app on your phone.
it will take a picture of the screen then convert all Japanese to English for you.
its a bit odd but it works
Hello again. I looked all over and I couldn't find no way of changing it from call audio to music audio. Under audio settings I didn't find no bluetooth option. Only under the phone settings. Maybe my version doesn't have bluetooth for music. [emoji19] if anyone knows at least I will know. I tried the Google translate. Worked
  • Sad 1
The confusion is that there are two sets of Bluetooth menus... There is the one under phone for setting up hands free etc. This is covered in the translation document pinned to the forum.
But then you need to find the bluetooth menu from the Audio menu, to set up the music streaming... To be honest it is quite similar to the G37 as many of the menus are the same, just in a different language...
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
