these here are my mates wheels i test fitted. They are 20 x 10 +30, The 19 x 10.5 +23 would make it sit out roughly 13mm more. With stretched tyres and the guards rolled should sit bang on i think. even if it has a little bit of poke. Who dosn't like poke ? :P
1598298_10152202293557697_3321513_n_zpsf
Edited by adambruv
  • Like 1
Well, good luck rolling plastic. You'll have to roll the guard that is behind the plastic, as it's just the normal one. Then you have to deal with the plastic.
And I don't like poke. It's for kids in civics with roof rack wind deflectors and huffy sliders...
dealing with the plastic is easy enough, ill just trim it like in the photo shown. Take the flare off, Roll the guard, trim the flare, put back on. Bobs your uncle.
1596441_10152202331832697_1028111319_o_z
Agree poke is gaids. As well as stretch.
Good luck with that, it is double skinned. I think he will have issues pumping it out much.
Take pics for us, I am sure there are many looking to upgrade to 10.5's, including myself, but I don't want to run 225 tyres, it defeats the point.
Is now the time for a physics lesson on why wider tyres don't put more rubber on the road, just change the shape of the contact patch...?
The exceptions are if you a) lower the air pressure or b) add more weight to the car (can also be weight added by aero at speed).
The biggest issue is in wet weather when the wider tyres aquaplane much sooner. Of course some of this can be offset by getting better performing tyres.
I suppose suffering for fashion isn't just a girl thing, lol.
Amazing looking car, I'm very jealous.
I am currently looking around to find something similar to your ride mate.
Not that it matters at all, but I gotta agree with some of the other folks here, poke and stretch just aint for me, it's more for those "civic kids" that speak in hashtags.... #yolo #nomakeup #nofilter #selfiefridays :P
Maybe I'm just showing my age a bit there but I like it just the way it is.
You're aiming to be a civic?
And you think there is something wrong with us...?
:rolleyes:
But srs, do whatever you want with your car. Its yours. But understand that not everyone is like omfgherrastancebrolostmyshiz over that kind of car.
Looks like it would be about as comfortable as a jackhammer.
This isn't going to be a daily driver then I take it? every time you go over a speedhumb... SCRUB, every time you go up a drive way.... SCRUB, every time you go over anything but mirror flat road..... SCRUB.
I think it looks good if it's parked for show at Autosalon, but I can't see it being great to drive.
As has been said, it's your car, do what you want and don't worry about anyone elses opinion. :) good luck
That is one of the definitions of a "hard park". They love scrub, if you do not scrub you cannot hard park.
Whatever floats the boat. If you love it you gotta do it.
I personally think the stagea looks good with a bit of poke n stretch with such low, but it just turns a practical car impractical.
Have fun and enjoy :P.
  • Like 1
haha defiantly not. Car only gets driven on weekends. Stored away in the shed during the week.
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
