Today i took some time, Gave the old girl and oil and filter change and also installed the battery cover over the power steering section. Think it looks alot more neat now. Also yesterday i picked up my sticker bomb roof wrap. Hopefully have that put on during the week and ill post some photos up :)
1609870_10152218306247697_1972949727_n_z
1604872_10152215700297697_833494373_n_zp
  On 30/01/2014 at 7:17 AM, joshm35 said:
do you have a pic rudi of yours as I was looking at gloss black
Yes i do josh. i think i posted it last year on what have done to your stagea, other wise i;ll take another shot and post it or pm your mobile number and i;ll send it to your phone :action-smiley-069:
ist under black roof. in what have done to your stagea, and you comented on it
  • 1 month later...
  On 03/03/2014 at 3:38 AM, GH05T said:
car looks good. looking forward to checking it out on AJP, hope your package arrives in time
i shall be there!
look what arrived today! Just in time, pitty one wheel is damaged but i have been given a refund of $150 to get it repaired which i am pretty happy about. Were still not sure why WORK wheels would send out a damaged wheel. anyways pictures bellow!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
