I have bought an R32 GTS-T and i was told by the guy i bought it off that it had a RB25 neo turbo/ an op6 on it. i had it on the dyno today and bumped it from 8 psi to 13 psi and it went from 127Kw to 166Kw but i still dont know if the turbine wheel is ceramic or not. i need to know if i can keep running it at 13 psi or not does anyone know if they came out only with ceramic wheels or is there a steel turbined op6.
https://www.sau.com.au/forums/topic/431289-rb25-neo-turbo-spec/
However, disregarding the aspect of luck involved in whether a ceramic turbo will die or not, running an R34 turbo on an RB20 at 13 psi is actually going to require less shaft speed than running an RB20 turbo at that boost, and also less than running it at 13 psi on an RB25. What this means is that you will be putting it under less stress and it will be safer than either of those cases.
I ran an RB20 turbo on my RB20 at 13+ psi for many years and it was still fine when I did my engine swap. The current Neo turbo appears to be quite happy at 12 psi, although I don't flog it hard and it hasn't been long and bad luck can happen at any time. Luck of the draw, your milage may vary, etc etc.
Havnig said the above, I hesitate to believe that you have an OP6 turbo (which can either be a VG30 or an R34, and they are slightly different) because at 13psi it should make a shit tonne more power than 166rwkW. I would have thought more like 180+.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
