I have bought an R32 GTS-T and i was told by the guy i bought it off that it had a RB25 neo turbo/ an op6 on it. i had it on the dyno today and bumped it from 8 psi to 13 psi and it went from 127Kw to 166Kw but i still dont know if the turbine wheel is ceramic or not. i need to know if i can keep running it at 13 psi or not does anyone know if they came out only with ceramic wheels or is there a steel turbined op6.
https://www.sau.com.au/forums/topic/431289-rb25-neo-turbo-spec/
However, disregarding the aspect of luck involved in whether a ceramic turbo will die or not, running an R34 turbo on an RB20 at 13 psi is actually going to require less shaft speed than running an RB20 turbo at that boost, and also less than running it at 13 psi on an RB25. What this means is that you will be putting it under less stress and it will be safer than either of those cases.
I ran an RB20 turbo on my RB20 at 13+ psi for many years and it was still fine when I did my engine swap. The current Neo turbo appears to be quite happy at 12 psi, although I don't flog it hard and it hasn't been long and bad luck can happen at any time. Luck of the draw, your milage may vary, etc etc.
Havnig said the above, I hesitate to believe that you have an OP6 turbo (which can either be a VG30 or an R34, and they are slightly different) because at 13psi it should make a shit tonne more power than 166rwkW. I would have thought more like 180+.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
