(Manual, 121,000km with light mods turbo 3 inch exh. pod filter, boost T. splitfire coil packs)
Okay so i spent all day re-spraying my rocker covers and spark cover...assembling everything back together..
the throttle body gasket bloody snapped, only like a quarter of the corner came off but there is still bit of gasket on there didnt mean too..so i was like 'meh' bolt it back up again..
then decided to go and spray the cam gear cover..in the middle of trying to take it out i rotated the TPS. i wasnt sure if i was meant to rotate it..cos the damn thing wont come off unless I screw off the bolt holding it in..so i was like f*** it..bolt it back up again..
Re-connected battery terminal, started up my car and it idled high at first then dropped back down after 10 seconds..to normal idle speed...THEN the revs dropped further, the engine was a little bit shaky and the exhaust tips were shaky as well..and it was blowing toxic fumes than normal..it sounds like it's 'put-put-put-putting' almost like a drag car with race cams..
please help ..cheers guys!!
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
