Hey ppls.
Just had the new cooler fitted and thought I'd port some pics for anybody interested in how it looks.
Its an R34 GTT
It an HKS Type S Intercooler kit.
I powder coated the pipes black (they were originally silver) for stealth, but couldn't decided on an appropriate coating for the cooler so left it uncoated.
They only had to cut the lower cross member.
All pipes went back to the original holes where the standard cooler goes.
Here's the pics.
BASS OUT
https://www.sau.com.au/forums/topic/43132-new-cooler-install/
looks great...... and thanks for the pics, thats exactly what I want to do when my cooler arrives.
Since you already been there, done that. Can I ask a few questions.
How much did it cost you just for the piping if you did it yourself or did you get someone else to install it?
Does the return pipe need to be bolted to the chasis?
cheers
It an HKS intercooler kit.
Comes with everything to bolt the kit up to the car.
Including a small bracket to hold the return pipe to the chassis and stop it from flopping about.
The long pipe which goes from the turbo side of the engine to the far side is actually the "hot" pipe, and the short pipe going to the intake the is the "cold" pipe.
Interesting.
Today, the mesh grills are being cut and put into the oringinal locations where possible and the cooler will be sprayed matt black for stealth (well, as much as possible anyway)
Will let you all know how it turns out.
BASS OUT
looks good!
just a questoin tho why was the return pipe plumbed back via the stock inlet pipe locaton vs going into the right hand side and using a 270 degree bend into the plenum? wouldn't it be better this way vs coming all the way back the same path?
Great because I have the exact same front bar. I was intending to go stealth too.
Thanks for that.
Why don't you cut away the extra number plate mounting area. That's my intention so as to not block the airflow. May have to put all new mesh in though.
RaulR33.
The R34 has a different inlet to the throttle body as it has a solenoid operated throttle before the normal one for traction control, therefore you can't put a 120 in there.
Secondly, I didn't want to cut the chassis for the pipe.
Thirdly, that's just how the kit came. Who am I to argue??
Abo Bob.
The bottom of the Nismo bar would be completely unsupported if I cut out the number plate section.
On a road car, the intercooler acts more like a heat sink anyway, by the time you heat soak the cooler enough to require bulk airflow, you would probably break something else.
On a race or track car however, airflow is important to remove heat from the core.
I also wanted full stealth for staying a little bit discreet.
Another note.
Boost definently comes on a little later, but no later than stock thanks to Roil.
I also fitted a lightened flywheel:
http://www.skylinesaustralia.com/forums/sh...2997#post882997
yesterday, which takes up the slack response.
BASS OUT
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
