Hey fellas,
Had an odd issue last night. I was driving my car about 10-15 mins into my trip and going along Cumberland Highway at about 60-70km/h when my car just stalled and i was rolling forward. My lights remained on and i immediately put on my hazards and pulled over.
My car then wouldn't start for about 5 minutes. I popped the bonnet and smelt something a burning smell. I can't be 100% sure if the burning was coming from my car or from something else that wasn't involved with my car.
I finally got to start my car and hopped in and got about 50 meters before it stalled again, this was just going forward and no deceleration (no brakes where used)
Took another 5 minutes before the car would start so i just pulled into a side street and switched off the car.
Tried looking for a towey to get me home, but luckily my mate lives near by. He jump started my car and i drove it home with no issues. At first i thought it was an alternator issue so i measured my battery with the car on which measured 14v (to my knowledge this means the alternator is fine? I could be wrong!)
Car is now at home and hopefully i can get some help what to check and what the issues could have been?
Note - Car battery is < 1 year old as well.
Any help would be appreciated :woot:
Thanks!
https://www.sau.com.au/forums/topic/431325-car-stalled-whilst-driving/
For future references. Took it down to JLM Great bunch of guys there.
They changed the CAS, AFM and alot of other things to try and diagnose the issue.
The problem was the Fuel Regulator.
Changed it boom fixed!
Great to hear its all fixed. Its good that from posts like these we gain more know-how as to what to look for when these symptoms occur to our cars.
Suspected Electrical fault turned out to be FPR.
Did you tow the car to JLM? Bet it wasnt cheap :(
Didn't tow it, i drove it haha. Luckily it didn't stall!
Within 5 minutes of arriving at JLM it stalled. Good thing it stalled then so it replicated the issue and also i wasn't stranded on the road :D
Other things they checked was my fuel pump, pump flow, battery related issues and many others but for the many hours they had it i switched off haha.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
