Hey all,
Can anyone suggest a shop I can go to around Sydney to get a battery which will fit right in? Car isn't starting on some mornings and just now after a drive it didn't want to start. Turns over then clicks, low on juice. Voltage when running is about 14 - 14.2v which would indicate the alternator is fine.
Ive called a few shops they all either cant be stuffed or don't know. Someone suggested "any battery will fit". Can't see how since there is very limited room. If I go dry cell can the battery be mounted flat? There isn't very much room at the moment between the speaker and negative battery terminal and the battery in there is tiny. Its a century branded battery and its much smaller than the battery tray in the car.
Sum it up, new battery from where, how much and wet or dry?
https://www.sau.com.au/forums/topic/431334-drop-in-battery-for-r33/
Get the model code off the battery? 45Z or something I dont know, If its a century battery it will be on there.
Depending on what you want will depend on where you go
If you just want another centry, run of the mill battery, go to supercheap auto
I don't feel this battery is suitable. It is far too small and since Ive had the car its always been abit laggy on cold morning starts. Also have a sound system in there, not too big but again a battery that small will be pushing it. Thinking of getting an Optima battery but unsure if they will fit.
Slip down to the Optima guys & let them do the thinking for you man. Done deal.
Cheers GW
I've just replaced my battery. After doing the ring around I ended up at Super Charge at Blacktown who found me a battery that was the same size - with the pencil sized terminals - that fit perfectly in the standard tray. The battery was a MF40B20L and although RRP was around $130 they let me have it for $90 - bargain. It's a fully sealed, maintenance free battery so no loose vapours in the boot and is rated at 360CCA which also aligns with the standard specs.
If your running a few amplifiers and like leaving the stereo on without the engine running, or you have one of those alarms that just loves to slowly drain your battery over a few days, I would recommend replacing your battery terminals for some larger sizes. You would then be able to get a fractionally larger battery rated to around 450 - 500CCA and that would keep you cranking on the coldest of mornings.
Z
I'll give them a call and see what they suggest. Just went down to the local and the chap suggested the same battery I got in there, the 40vlsx or something or rather. I don't leave my stereo running when the car is off, but I do think my alarm is one of those drain your battery in two days type.
Zane can your sealed battery be fit in any position?
Just an update.
Called up a few places, ended up going with a SuperCharge MF75D23L. Was only $140 so not bad at all. Has twice the cranking power compared to my old battery, much larger, greater capacity and its sealed. It was a straight fit, old terminals were fine but I had to make a longer securing bracket on the top of the battery. 5 minute job.
If you're after a battery for your R33 and need something a little bigger, consider the MF75D23L. 3 years replacement warranty too.
Edited by SargeRX8
  • Alarm (pretty common, pulled a faulty one out of my mate's car not long ago)
Ghey window lift kits
ABS relay constantly on
Relay for ECU on, constant power to it
Faulty Amp, constantly staying on regardless of trigger wire
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
