I have just done a single turbo conversion on my GTR so I have some stock parts for sale
Parts are from a 2000 R34 GTR with 93,000kms
Available for pick-up or post at additional costs
Pick-up in Kallangur, North Brisbane
Call during standard working hours 8am - 6pm on 0488083818 or PM on here for any additional info
More to be added in the coming days.....
BNR34 Stock fuel pump and lines $60
BNR34 Fuel rail / Injectors / Stock FPR $250
BNR34 Stock Turbo's, Manifolds, M's pod filters, Standard AFM's, All pipes (Inc a custom Stainless twin 3" into 3 1/2" front pipe)
Turbo's are in perfect working order and made 257kw @ less than 1 bar on my stock BNR34 the day they were removed (Dyno sheet can be provided) $1200
BNR34 Stock Suspension, removed @ 90,000kms
Perfect working order, no knocks etc $200
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/
  • 3 weeks later...
Once again all parts are off my 2000 BNR34
AFM's $100ea or $150/pr
Cams & Cam Gears $100
ECU $250
FRP Front Bumper Vents $200
Rear Bumper Lights $200
Turbo's, Manifolds, Dumps with stock actuators & O2 sensors $400ea or $700/pr
Custom Stainless twin 3" into 3.5" Front Pipe $300
M's Pod Filters $50
Orange Side Fender Indicators $20
Orange Front Indicators $25
Twin Turbo Pipe $80
Items located North Brisbane, Prices are for Pick-up
0488083818
Cheers
Noy
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/#findComment-7042415
  • 2 months later...
Bump, New Prices
Rail & Injectors $200
Standard Fuel Pump $50
ECU $200
AFM's $100/pr
FRP Bumper Vents $100
Fog & Reverse Lights $100
Turbo's, Dumps & Manifolds $500/pr or $300ea
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/#findComment-7155081
  • 4 weeks later...
AFM's & Stock Suspension have gone..
Items still available
Fuel Rail & Injectors $200
Stock Fuel Pump $50
ECU $200
Bumper Vents $100
Fog & Reverse light $100
Twin Turbo Pipe $50
Additional Items
Stock 34 GTR Rotors F & R $100
Momo F1 steering wheel & boss kit originally came in the 34 GTR $100
Personal steering wheel & boss kit off 33 GTR $50
https://www.sau.com.au/forums/topic/431362-r34-gtr-parts/#findComment-7176422
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
    • If you need to refinance your mortgage and reset the loan terms back to 30 years and cash out on your equity for "investment" purposes *cough* car parts, I can help 😊
