Guys its Up for sale again. It has a mod plate everything is legal.
One and Only V8 R33, has run a 13.38 at willowbank and stock 205's!!!!
Black, auto.
Nissan Infinity VH45DE 4.5Ltr All Alloy Quad Cam V8
Custom Extractors to full 3 inch Mandrel Exhaust.
Pod
Biggest Transmision Cooler Available
17" chromies plus a full set stock rims.
Garage ***ui Front Bar and Side Skirts, Custom Made Rear bar
Stealth Spoiler
CF Bonnet
Original Floor Mats
Custom Silver Dash
Momo Steering Wheel
Apexi RSM
Slightly Lowered
Stereo:
Alping MP3 Head unit
Alpine Type R 6.5" splits
Alpine Type R 6 x 9's
2 x Alpine Type S 12's
Alpine MRV-T420 Amp
Alpine MRV-F540 Amp
Clarion TV HeadUnit
X-Box
Full Custom Boot Install
Stereo Alone Worth 7500...
Asking 35000 ono
Willing to swap for a 33GTR possibly 34GTT with cash difference.
Phone John on 0417 608 538 or PM me on here, or email [email protected]
https://www.sau.com.au/forums/topic/43142-auss-only-v8-r33/
Thanks Guys, basically ive achieved everything i set out to do with it, V8, get it in a magazine, now before i continue to spend money on it i will buy something different and start again with some different goals.
https://www.sau.com.au/forums/topic/43142-auss-only-v8-r33/#findComment-881190
i can vouch for this car... saw it when it was being built and have been in the finished product 4 or 5 times a week... if you like people looking at you with a confused look this is great also great for speed and power and the grunt oh my god the grunt.... if i had the money i would have snapped this up already but i don't so its open to the rest of you...
https://www.sau.com.au/forums/topic/43142-auss-only-v8-r33/#findComment-882061
not to hijack your thread... or to give you shit...
but you think someone will pay 30g's for it when they could get a r33gtr?
have you seen this thing run? it deserves 30gs at least. and how many GTRs do you know of that puts out 600nm of torque?
https://www.sau.com.au/forums/topic/43142-auss-only-v8-r33/#findComment-890184
didnt the conversion cost 10k and the car cost about 15k? that = 25k to me...please correct if im wrong
that doesn't include labour.... and everything else done to the car.... even if the conversion only costs 4k it is still a one and only and if you want your car to be unique then people will pay what is asked not what was spent.... if you saw a car on hear and they spent 50k on a conversion of some sort and sold the car for 30k would you ask questions?
https://www.sau.com.au/forums/topic/43142-auss-only-v8-r33/#findComment-891777
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
