Hello guys,
I planned to buy every single bushing/metla spacer, along with their fan for my BNR32, order was about 200$ but shipping was 70$ to canada.. so I had second thought, my mechanic told me it was useless and I wouldn,t notice a difference beside maybe the shiftter metal collar.
Whats your thought ?? Have you guys tries these item and felt a difference in the way the car handle/react ?
thanks!
I havent tried Gktech, but on my S15 I put Whiteline subframe collars, and there was definitely a difference. Not enough to notice on the street but at Wakefield (NSW race track) power transfer felt solid, and the rear end felt planted through every corner.
Locking up the rear subframe is a good thing - from the point of view of holding stuff together and making it work better. It can and will make a lot of extra noise and harshness come through to the cabin though, so you have to decide what you're willing to put up with.
FWIW though, I am now a firm believer in not sticking crappy add-ons onto the subframe. I pulled mine out and replaced the main bushes with new ones, which are much firmer than the old originals. Previously I had old originals + collars, and I couldn't say that removing the collars has made it go backward. It feels at least as good as it did before.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
