5K is ok so is 6, after 7 is where you need to careful
Nuh I never go past 6. Unless I track my car, which I haven't done yet.
Well that's just boring, this thread isn't about thrashing at all!!?? Take it to 8, that's where the fun starts ;)
:laugh:
Op,
Looks like the "seasoned" members have come in.
What is your definition of thrashed?
As far as I'm concerned you can run a car hard (within reason no boucing of the rev limiter for ages, no flat changing) and as long as its properly serviced it will be fine.
If a car cannot handle being pushed to the limits day in day out with SOUND maintenance than it is a piece of shit that is not worth your time.
To me thrashed is hard driving without maintenance. That is what will destroy an engine, gearbox etc. Chasing 300kw on a stock bottom end.
Drive your Skyline hard and service it fastidiously. It will last you a long time.
Edited by Legendaryl
  • Like 2
Also I would say knowing what pinging is and what it sounds like is beneficial.
A very good idea in general, but often it is hard to hear when you've got a helmet on.
This. I used to be paranoid about turbo motors but they will handle it if you have looked after it properly.
1) Fresh oil, put an extra 500mL in and go a touch heavier in oil thickness than usual but only if you will do several laps at full noise. I recommend something like 5W-40 for general street use and some light "exercise". Last track day I did I put 5W-50 in which is probably overkill but gives you peace of mind - the oil won't break down unless you go way too far on temperatures.
2) Make sure water levels are fine and that your radiator is in good nick. I did a track day once on a blocked radiator (mechanics mixed red and green coolant without my knowledge) and it got a bit toasty. I now have a thicker than stock aluminium radiator and have no qualms about giving it more stick. There is a standard water to oil heat exchanger which is intended to warm up your oil on cold start, to a degree this will also help keep a lid on oil temperatures if your water temps are solid (ie water temp 85C oil temp 120C the oil is going to be dumping heat back into the cooling system which then dumps it out via the radiator).
3) Don't limiter bash it. Accelerate smoothly up to just before redline and then change gears. Don't leave it off throttle just below redline, ie corner entry.. I try not to be off throttle above 6k RPM as much as possible, use your brakes to slow the car down not the engine (I only break this rule when I really need to be in that gear for corner exit)
4) Make sure the fluids are warm before you flog it, and give it an easy lap to cool down before you come back in. Check the car throughout the day for any leaking fluids, temperature problems or something that doesn't look right.
5) brakes. fresh pads and rotors in good nick. make sure you bed them in at least a week or two before the track day. new brake fluid before a day is a MUST - DOT4 or super DOT4 or DOT5.1. Do not use DOT5 as it doesn't handle water ingress well and has a very short lifetime inside the braking system. DOT5 is only for cars that are frequently tracked and fluid changed.
With proper care I had no problems giving it full noise for a full 20 minute session. Car loved it. Of course, if you are running a lot more power than standard and you have done nothing to help your engine keep cool then you will be in trouble. Nissan designed everything just fine for standard power levels, but people wonder why they get a 280rwkw tune, do 10 hot laps on the stock radiator with no oil cooler and pop a motor. Not rocket science, more power = more heat. Gotta get rid of it! Stock power levels are fine with stock equipment.
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25 The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
