gregando Posted September 6, 2013 Share Posted September 6, 2013 (edited) i just replaced a broken pivot ball in a R32 5 spd and the clutch still isnt dissengaging, it wont let me select any gears and drives with the clutch in when putting it in gear befor starting ,its no different than befor i replaced the broken pivot ball . does any one have any sugestions as to what it could be. it has a rpm 5 puck ceramic clutch and both the throwout and clutch are only a few monts old . Edited September 6, 2013 by gregando Link to comment https://www.sau.com.au/forums/topic/431459-r32-clutch-not-disengaging/ Share on other sites More sharing options...
GTSBoy Posted September 6, 2013 Share Posted September 6, 2013 Have you checked to see that the slave actually moves the correct amount when you push the pedal in? Link to comment https://www.sau.com.au/forums/topic/431459-r32-clutch-not-disengaging/#findComment-7007856 Share on other sites More sharing options...
gregando Posted September 6, 2013 Author Share Posted September 6, 2013 yeah seems to have plenty of movement ,how much travel should the slave cylinder / clutch fork have when the clutch is fully depressed is there a measurenent? Link to comment https://www.sau.com.au/forums/topic/431459-r32-clutch-not-disengaging/#findComment-7007873 Share on other sites More sharing options...
gregando Posted September 6, 2013 Author Share Posted September 6, 2013 what other problems could cause this all thats been done is the pivot ball but it was a bit different to the broken one, the ball that broke was tapered on the back of the ball the one that replaced it was flat they looked the same length but could this cause it to do this, maybe when the ball broke is it possible that the clutch fork could of bent or could it be an adjustment problem its got me f**ked Link to comment https://www.sau.com.au/forums/topic/431459-r32-clutch-not-disengaging/#findComment-7007895 Share on other sites More sharing options...
D.I.Y. Mik Posted September 10, 2013 Share Posted September 10, 2013 Id say something else broke too. Or bent like you said, probably when the pivot broke. Maybe that something happened first and broke the pivot. Gtst? GTR? Single plate? Double? Probly have to take the box off again, and check it all out. I had a lot of trouble with the retainer spring popping off. Then when i tried to put it back the thrust bearing was jammed, and i had to unjam it. Which popped the spring off..... Got there eventually. Link to comment https://www.sau.com.au/forums/topic/431459-r32-clutch-not-disengaging/#findComment-7013121 Share on other sites More sharing options...
