i just replaced a broken pivot ball in a R32 5 spd and the clutch still isnt dissengaging, it wont let me select any gears and drives with the clutch in when putting it in gear befor starting ,its no different than befor i replaced the broken pivot ball . does any one have any sugestions as to what it could be. it has a rpm 5 puck ceramic clutch and both the throwout and clutch are only a few monts old .
Edited by gregando
https://www.sau.com.au/forums/topic/431459-r32-clutch-not-disengaging/
what other problems could cause this all thats been done is the pivot ball but it was a bit different to the broken one, the ball that broke was tapered on the back of the ball the one that replaced it was flat they looked the same length but could this cause it to do this, maybe when the ball broke is it possible that the clutch fork could of bent or could it be an adjustment problem its got me f**ked
Id say something else broke too.
Or bent like you said, probably when the pivot broke.
Maybe that something happened first and broke the pivot.
Gtst? GTR? Single plate? Double?
Probly have to take the box off again, and check it all out.
I had a lot of trouble with the retainer spring popping off.
Then when i tried to put it back the thrust bearing was jammed, and i had to unjam it.
Which popped the spring off..... :rant:
Got there eventually.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
