Also just to note, It looks like production sports cars, are going to allow R32,33 and 34s run in there class. So My Co-driver in the excel cup class and I are going to run the boat in the CUE one hr event next year.
So I'm pretty happy. I can run the car in QR sports and sedans, Improved production (with a turbo choker) and now or soon to be Production sports cars.
It's looking like the skyline is a good choice.
Righto... continuing the build of the ECU and I'm up to the point where the stock ECU case is now gutted and the connector block desoldered from the original circuit board - I hacked, cut and mangled it pretty bad to get it off the connector, but the end result was good - all the connector pins are healthy and intact.
The new MS3 module will fit, but I do need to create some standoff brackets so that it is well secured and pro-like. I could just pack the module with silicone and/or leave it free floating, but I'd like to do this properly and I think a few plastic plates made with the Dremel won't take too long to whip up.
Both brackets made and MS3 Pro module is mounted.
Next step is to think about how to mount USB/Serial connectors for software control, and also think about a secondary connector for things that can't be connected via the stock Nissan connector and harness. I think a trip to Jaycar is on the cards.
Ooh sounds like a project that I'd start and never finish - ending up in a car that doesn't work!
I know enough about electronics to get into trouble...
I admire your skillzzzzz
Which is part of the reason why we've taken to a spare stock ECU and gutted it instead of the original ECU (which only cost under a $100 to source a 2nd hand auto module with the correct harness connectors).
If at any stage we can't get the new MS3 Pro module to work we can fairly easily swap back the stock ECU and with a few minor changes to the intake sensors, be back to working again. The overall goal will be to have MS3 manage custom tune mapped at the dyno with a electronic boost controller making crazy HP. If we have to swap the stock ECU back, it will just mean the engine will run without extra boost and run pretty much like stock. It should be a good solution for getting all the features of a $2000+ ECU system but hopefully come in under $1000 !!
Oil cooler in
Replaced knacked water inlet pipe on the manifold.
New S/S brake lines
New Discs and MU pads.
New Camber and caster adjustment arms front
Lock out and Camber arms rear
$10 worth on paint on the wheels :yes:
Cage should be here from AGI next week and so should the KAAZ 2 way.
BTW aero bonnet cilps suck balls to install!
Off the blocks,
Quick drive up the street, all seems good, wife hates it. So it must be cool ;)
Ride hight is a little low, need to raise it about 20-30mm, I'll have to wait till the coil overs settle. Sold a bit of gear off the car, so I should come in around the 10k mark. Seems like I'm under tired in the rear, with the 225s, I'm having a look for some 9" wheels so I can fit some 255s or 265s. Got to love motor sport, you can spent 100k plus on a motor, but go wider than 9" on a rim and you can't race :rolleyes:
Cheers,
Really hanging to get out on the track.
I was aiming for the next round of qr sports and sedans. Which is on the 3&4th of nov. I'll be pushing it to make it. Don't really think taking a untested car racing is the best idea. Might have to do a couple of track days and
There is always next year. 1st world problems eh!
Nup,
I've got to add another axle to the car trailer as well. So there's no hurry at the moment. 1300kg car on a single axle trailer is pushing it.
I'm going to miss the next race meeting.
So I'm going to do testing and get it ready for next year.
Any way I've ran out of parts, so your more than welcome to come over and sit in the paddling pool and drink beer!
Did some more work on the custom ECU today. Added a USB-B connector (for software uploads and tuning) and a 12V power plug (for bench testing out of the car).
Once the wires had all been soldered in the right spots, I switched her on and uploaded the latest firmware to the board.
Everything went perfect and sweet - next step is to begin the wire-up to the stock connector.
Edited by gslender
  • 5 weeks later...
Well, it's been a while,
I got smashed with work, still pays the bills.
Cars all most complete, off to Ken @ Accurate Suspension, on Monday for the Alinement.
Little update.
The best tool in my shed, under a grand, does the job welds locker diffs, and parts I need for the car. I've never taken a welding course, just a little shed time. I'm no gun but, I've built my own trailer harness point exhaust parts etc. I figure if I hit with a big hammer she's all good in the hood.
I've got stuck into the guages and kill switch this weekend.
New 2 way diff
Bumped into a bloke off loading his race wheels and tires, 295 35 R17, should grip!!
I bitter that I missed out on running last week, so next date is going to be on the 14th Dec @ QR for a sprint meet, fingers crossed.
Just got to add a extra axle to my trailer, don't like the idea of a 1300kg car on a single axle.
Cheers
Grants popping over this weekend, we are hopeful the ms3 is going to fire.
Also found out the front of the car has taken a hit in the past,slightly bent driver side . So I'm having the front camber arm machined. To allow for a little more camber on the driver side. To straighten up the alinement.
Can't wait to get it on the track.
Looking forward to a little dickyspeed master action ;-) I'm going to be pretty slow, I've not had a drive for about 6 months.
Mad soldering skills!
I'm not drinking tonight, so I won't be hung over. Think this will be the first time we've worked on a car, with me been sober!
Don't know wether that is a good thing or a bad thing, haha.
Can't wait to start logging data again, I'm really missing tuning studio!
Well the MS3, went into full fail boat mode!
So we are going to leave it for a xmas build, while we have a rethink. I.E. read the bloody RB25 circuit diagram. So screw nissan
and there ECCS relays!
Should be all good. What we are trying to do, is use the standard loom and make it plug and play with out cutting into the stock
loom to much, when I say we, I really mean Grant! I'll take to a supercar with a angle grinder.
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
