The car is pretty much complete!
So I've also entered the car in it's first event on the 12th at QR, I be very happy if the car doesn't break.
So fingers crossed.
I'm really looking forward to getting it out on the track!
Cheers
Did I read right a fee posts back 295's on the rear? Thats FAT as. They wiuldnt fit would they without a fair amount of work??? Absolutely fabulous build mate. Lovr the comment "THE WIFE HATE'S IT SO MUST BE COOL" HAHA HAHA.
Cheers Josh
Hi josh,
Yep 295s, there on 9.5' rims. Just fit. Rolled the guards then used a slide hammer. It's a 20ft car and the tyres where pretty much free.
When I had the alignment done, it was doubled checked for clearance. All good. I've done a couple of hot laps up and down the street no rubbing.
Just have to wait and see if there good on the track.
The bloke I purchased them off use to run them with no problem.
Thanks for the reply.
The good, bad and the ugly....
Ran today out at QR, Very wet. Ran the National circuit car was great, just took it easy, getting a feel for the car and the fact semis in the wet.
Oil temp max at 95° Water temp 100° O2 WOT 11-12 ratio nice and safe @9PSI. easy 200 kph down the back straight. Project MU pads are unreal.
For the ugly, just started to try and push on the sprint track. Gear box dropped a poo poo valve. Lot's of grinding.
On the bright side I've just picked up a new rebuilt gearbox.... I'm not looking forward to dropping the box out though.
Still that's motor sport. Build it, race it, f#%k it and then fix it HAHA!
  • Like 1
Quick up date.
Old gearbox out, as my mate put it, "Awwww, the gear box has had little baby gearboxes".
To be honest, can't see what the big deal is about pulling these gearboxes in and out, I had a couple of reads online about, how much of a pig they are to get in and out. Think some of these people need to grow a set. I did mine on my own with a trolly jack. the one thing, which really helped was an 1 meter long extension bar, to get the top gear box bolt.
I was really happy to find a new Exedy HD clutch and a new flywheel.Also a new Gates racing timing belt. Someone must have cared for this car in the passed.
I'm installing a new rad, intercooler and oil lines. Almost complete.
Will update with pic later.
Hope everyone had a nice Xmas and all the best for the new year.
Regards Nigel.
  • Like 1
  • 3 weeks later...
Hi All,
Hope your new years as started in the right way, I spent mine, surfing, fishing and drinking way too much... Northern NSW is bloody tops!
Started back on the car. I've already learn some new things this year.
OEM fitment means, you’re going to have to cut the sh#t out of your car to make it fit.
Universal fitment means, it won't universally fit without a lot of swearing.
And real race parts never come with instructions.
Fixed up the exhaust. The cat had about 160Km's on it. When I looked down it at the light, I could see none.
Welding seems to be getting better. Flanges and flex pipe are from ECS, online price are good and ship on time.
New intercooler
Welded in a new support bracket, for the intercooler which helps tie in the oil cooler lines. 25mm RHS 3mm thick
New rebuilt gearbox, solid mount and clutch slave.
New short shifter , as the S1 R33 gear box shifter, doesn't have the same fitting as a S2 R33 gear box, by the looks of it. I could be wrong? If any one knows please sing out.
Thats for that,
Nope I didn't rebuild the gearbox, A mate of mine has a 700 plus horse power R33 GTST. It ate this gear box, he had it rebuilt and didn't use it and went to a Sequential shift gear box. I'm under stock power, so this should be more than up for the task.
Should be back down on the ground by Sunday fingers crossed.
  • Like 1
Is it still street rego'd?
Such a good car to build, sort of wishing I did this instead of an S14 now.
Thanks for the kind words,
I let the rego lap’s.
I've got a work ute there was need for it to have rego. I still run it up and down the road every once and a while, just for test hits.
My last race/track car was, but it's a lot of money with rego and insurance to have sitting there. Better spent on go faster parts. I.M.O. Plus some QLD PD don't have a sense-of-humor.
I was looking at an s14 or s15, but I just don't fit. I'm too tall. I only just fit in the r33 for head room.
This is how I had my mx5 set up with the seat on the floor. LOL
All set for another crack at QR tomorrow, fingers crossed the car will last the day
Completed the exhaust.
Installed a catch can. Really like the push loc fittings, much better IMO that S/S braided hoses,
I'm thinking about running in PSRAQ, so I've got to install all the stock light fittings etc.Still carbon them up a little.
I also was given a GOPRO for Xmas, but I have firm though's about posting footage online. I.E.
IMO, it's a little like masturbating in public, it might make you feel good, but most people are going to think your a wanker! But most my mates think I'm a bit of a wanker anyway, so I may post something if I think is cool or if I crash,
Edited by toppertee
  • 1 month later...
All looks great man!
How did you go at QR?
Also, are you happy with the AGI cage? Fitment wise?
I have an AGI half cage in my car and the quality is great, but looks like I'll be going to the National spec cage soon.
Cheers.
I broke the car again... Head gasket what a P.I.T.A.
AGI cage is great, the only problem I have is i'm quite a big person, 6'2 about 95kg. So I've had to mount the seat on the floor, so my head doesn't come in contact with the top of the cage.
It's quite hard to get in and out of the car, because of the side bars, I'm going to get a removable steering wheel, which should help. I find it little hard to heal toe, because the cage sits in a little. But I'm going to mod the pedal.
The fitment of the AGI cage is tops. Plus aussie made and owned.
Well changing a head gasket in r33 is about as much fun as a solid kick in the nuts!
block looks good,
Had Torque team do the machining of the head and manifold
Head on a torqued down
New exhaust studs
New hoses under intake
Fat fingers and Skyline intakes don't mix.
Good news is I may have over tightened the cam belt!
This would be one of the most shitty jobs I've ever done.
I was getting pretty close to throwing a match at it :wacko:
I ran it at lakeside, last saturday, with out a problem, all most felt like buying a lotto ticket on the way home. Nice to roll the car on to the trailer, with out a list of stuff to fix.
I'm lucky enough to be running in the QR 300, in May. But the skyline was going to cost to much to mod and run. So I'm going to be in a mates 86, which should be fun. Fingers crossed I keep it out of the wall!
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
