Hey :)
I am doing a complete overhaul...
Upgrading and refreshing everything. So at the moment it's garaged and out of action :(
Which sucks, but it will be worth it :D eventually!
ii
Hey, how's the Skyline going?
Hey :)
Ohh big effort, I'm just in the middle of the same thing.
What are you doing engine wise??
Hey :)
Are you running twin or single turbo and are you still running AWD?
It's a single turbo and it's rear wheel....I've got a R33 GTSt...my name has GTR in it because GTSt_girl was taken haha.
I'm pulling the head off, getting it machined and match ported
all new valves
hks drop in cams
HKS cam gears and timing belt with a clear cover
tidy up the injector and coil harness
relocate the igniter
new water pump
upgrade from a mechanical to a thermo fan
heavy duty clutch kit
coil overs cause mine are destroyed
full nolathane kit for rear diff cradle, steering rack, sway bars etc.
bendix ultimate brake pads
overhaul on calipers
And basically a once over to suss whatever else needs maintenance as it's a 93 and I have given it a whooping
Just some of the goodies
When I manage to find one/afford one I want to put a GTR spoiler on.
GTR badge for the boot
full respray
replace the carpet
retrim
that's about it...just trying to keep it as standard looking as possible.
I only use GTR and nismo parts, no knock offs or fibreglass crap...so things are expensive thought worth it haha.
what are you doing to yours?
full respray
replace the carpet
retrim
That sounds really good!!! Your 33s pretty good! Like it's not something I'd expect a girl to have the keys to haha but that's awesome, girls who build cars.
Well you're in luck! I have a GTR spoiler here, it needs paint but that's normal.
Um well last time we spoke it was stock as a rock but so far I've done:
Return flow catch can
Alloy radiator
Greddy inlet manifold with 80mm TB
Godspeed hybrid FMIC
Turbo smart plumb back BOV
Cps full exhaust 3.5" with 5" decat and cannon
Bigger injectors with side feed rail
Spit fire coils
New plugs
Upgraded MAF and pod
GTR grille
Drift tecs
White carbon cluster with blue and red lights
New dash
New seats
Walbro 410LPH pump
Fuel regilator
Power fc
And more
Haha thanks, I get that a fair bit. Love my cars :D
How much would you sell it for!? Been after one for forever haha
Yours is starting to come together quickly. Happy with it so far?
Alloy radiator
Spit fire coils
New plugs
GTR grille
Drift tecs
New dash
New seats
Walbro 410LPH pump
Fuel regilator
Power fc
And more
Hey Brodie!
Yeah i think I've met like 3 girls in my whole life who don't roll their eyes when cars are mentioned haha
Yeah I'm so happy with it, can't put the tools down, or my bank card for that matter
SORRY LAND son of rajab ;)
But yeah they're fun cars to play with!!!
Mmm I'd sell it for $500 x 2 / 4 -100 x 3 - 300
;) have fun with that
Welcome to the SAU world Brodie! Female + Skyline = :wub:
Your car looks Awesome with those Rims and a GTR Wing will Definately be Tougher than the series 1 wing but please, for love of the God of Boost, don't put a GTR badge on a Non GTR. :/
Having said that, Enjoy your car and all that SAU can offer. :thumbsup:
all new valves
hks drop in cams
new water pump
just some tips....why all the headwork....you want a better flowing head just put a neo head on it...either way its a waste of time really...dont bother unless its stuffed and needs rebuilding...bendix pads are junk and will dust up those beautiful wheels like crazy...putting a thermo fan is not an upgrade...its actually a downgrade...
full respray
replace the carpet
retrim
ok you lost me now...:glare:
do not put a gtr badge on.
or do. i dont care its your car.
welcome.
inb4 all the forum sex pests show up.
nick? :whistling:
but you're already here.....
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
