I know guys, this topics been done to death 3 times over, but I can't seem to decide on a turbo that meets my needs. Chasing 220 ish rwkw but I need advice with the choice of turbo as I've got the fuel system, cam gears and nistune already done. Any recommendations? I was thinking a TD06-20g or a HKS2530 but I can't find a 2530. Any advice would be welcome, dyno sheets would be a plus. Cheers in advance. *Flame-suit on!
https://www.sau.com.au/forums/topic/431501-rb20det-turbos/
You take standard turbo off, send it off get it high flowed and it bolts straight back in and looks 100% standard.
stao can machine the factory compressor cover to bolt onto the ss1 and weld up the rear housing adapter to look stock
https://www.sau.com.au/forums/topic/431501-rb20det-turbos/#findComment-7010187
The Minister of RB20dom Roy has been researching this stuff for ages and there are lots of threads here to read through .
I don't think there is a "perfect fit" , to owners taste not spanner stuff , for an RB20 because everyone's expectations are different . Half the hassle is getting a different turbo in and running and then liking/living with the results .
Only you can know what power curve suits you and simply setting a number isn't much of a guide to your likes . 220 wheel wasps should be easy peasy for an RB20 but the $64 question is how much headroom do you expect beyond that . If you don't need any then sure a HKS bolt on like a 2530/2535/GTRS should get you there easily enough . The GTRS would go a bit further too .
The real questions to ask yourself are 1) budget 2) how standard it has to look 3) how far you're going with this engine/car 4) best power curve to suit YOUR driving style .
Physically the hardest part to get right is the turbine housing because it has to suit the turbine/the manifold/the dump pipe/boosting characteristics . The HKS turbine housing does a reasonable job of all these things in that power range but they aren't often cheap and easy to get . Sometimes the go is to buy someone's trashed turbo cheaply and use its housings if they are undamaged .
The best thing to do is go for a run in other peoples GTSTs and see what drive characteristics you like best .
A .
https://www.sau.com.au/forums/topic/431501-rb20det-turbos/#findComment-7011198
I've just slapped an HKS 2530 on my rb20. It is a little laggy, doesn't reach full boost till 4k. A better flowing manifold and a re-tune of the Nistune might help, but it pulls nicely to 8,300rpm. For what I paid for a 2nd hand one, I could have just gone for a hypergear highflow, maybe that's the better option..
https://www.sau.com.au/forums/topic/431501-rb20det-turbos/#findComment-7011433
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
