Nissan Skyline r33 Gtst 1995 Series 1.5 Manual coupe White 182,000kms Rego til 19 april 2014
Car Located in Newcastle, NSW.
Selling a r33 in excellent condition Front bar and bonnet freshly resprayed to remove stone chips. majority of the things listed have been installed within the last 10,000kms. I have had the car roughly 4 years, only put 30,000kms on it in that time. Selling because i work fly in fly out to darwin on a 4/1 roster and don't have time to appreciate the car.
Some mods include
Just Jap Front facing Plenum
Vulture Large 80mm Throttle body
Split Fire coil packs / iridium spark plugs
Greddy profec B Boost Controller
GFB Stealth Blow off Valve
Greddy turbo timer
Apexi Intake kit with air box
Front mount intercooler
Full stainless exhaust system
Walbro High capacity fuel pump
HKS F-Con S ECU Tuned to 200kw at 12 psi on stock turbo
$1500 sound system - four 6 speakers ,12 inch sub , amp and head deck.
Wanted price for car : $7800 . open to any offers.
Any questions about the car you can ring or text me on 0400036495 or PM me on here or email : [email protected]
As i work in Darwin, i am back in Newcastle one week out of the month but if you would like to see the car at any time i can organise someone to assist you.
$7800 ono
only Enquire if your interested please
post-77683-0-60813200-1378551841_thumb.jpg post-77683-0-87688700-1378551915_thumb.jpg
post-77683-0-00196600-1378551946_thumb.jpg post-77683-0-92721900-1378552002_thumb.jpg
post-77683-0-38181500-1378552106_thumb.jpg post-77683-0-16467600-1378552150_thumb.jpg
post-77683-0-07739900-1378552194_thumb.jpg post-77683-0-75499300-1378552233_thumb.jpg
https://www.sau.com.au/forums/topic/431508-for-sale-r33-gts-t-series-15/
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
