Turbo/fuel Upgrade On 2.7 Stroker Thoughts?
GTRB27
 Share
Hi all
I've had my built done early this year
New N1 block, Full nitto 2.7, Nitto oil pump, Extended sump, ATI
{Ported head with the works( cams not sure came with the car 250-260)
-5s, Tomei dumps, Front pipe, Hi flow cat, 3.5" exhaust
700 inj, Fuel pump not sure, Os giken 5speed/clutch
Haltech platinum pro......
The car makes 360awkw 24psi on 98
And its a weekend car maybe 1 track day a year(been once in 3 years)
I am starting to get few thing for my upgrade soon already got front and rear nismo diffs with bearings
This is going to be the last upgrade for a while LOL(that's what I said 2 years ago when I got my -5s)
TURBO 450kw+
-pt6466 Cea I know its going to be more laggy I thought somewhere in the middle not sure about A/R?
-Twin scroll mani ?
-Twin or single gate and the size?
-Dump?
I have got a Apexi drag intercooler 700x300x140 collecting dust :ninja:
-What size cams?
FUEL want to run eflex
-Fuel pump/pumps?
-Id1000/2000?
-Fuel regulator?
-Fuel rail?
-Fuel lines?
Do I really need a surge tank?
Just wanted to know your thoughts/experiences
Thanks in advance
Hi all
TURBO 450kw+
-pt6466 Cea I know its going to be more laggy I thought somewhere in the middle not sure about A/R? 6262
-Twin scroll mani ? yes
-Twin or single gate and the size? single 44
-Dump? straight out the hood
-What size cams? tomei type b
-Fuel pump/pumps? stock in tank to Radium surge with twin aeromotive 340s
-Id1000/2000? id1300
-Fuel regulator? aeromotive
-Fuel rail? modified stock
-Fuel lines? stock
Do I really need a surge tank? no, but its easiest
Thanks in advance
bippity bip bop boo
Edited by black bnr32
What is your power target and how much lag can you live with? Your description gives little to work with, I am guessing stepping up in power is the target but how much - and how much less streetable can you handle?
If it was me id be pushing them -5's as far as they'll go before changing the whole setup for 450ish kw. Then if your disappointed ("highly doubtful though") then upgrade to to the 6466. Your choice at the end of the day though.
Josh
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
