Well after a 10 second google search it showed this
http://www.cybermotorsports.com.au/
I did the same search 6 months ago. I then contacted the editors of Fast Fours & Rotaries and Hot Fours for details. I then contacted the number on website many many times - doesn't connect. I then visited address on website and they aren't there anymore in Carlton and haven't been for some time. It is as if they just disappeared. I have also conducted an ASIC business name register search and the company is still registered, but the address is same as website. Via rumor alone, I have heard that he ran a coffee place in the airport - but this cannot be confirmed. I have also conducted an ITSA and Supreme Court search and they did not go bankrupt. So now I start a post to see if someone knows following my extensive litigation turning up no result.
Now back to the subject of your above post... Thanks for suggesting Google, I guess?
The scene has changed a lot in 15 years and if you don't move with the times then you will no longer exist
This is true of businesses generally. However, they did move with the times/scene, as Danny was an actual artist and went to Sydney uni and held a degree in fine arts. His designs and kits were his own and he did kit and paint some awesome R34 GTRs, this may date Cyber within the last 15 years? They were still operating as recently as 3 years ago. The car that put them on the map was the Cyber Predator kitted prelude and Honda CRX. Cover of the first issue Fast Fours and Rotaries.
  • 2 years later...
Guest
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
