How can I open my boot, on my 1996 GTS skyline.
Should I see a locksmith / panel beater / mechanic or is there a simple way to attend to this?
My son was playing around with the boot mechanism and he pushed something into the down position.
Now I can not open the boot from inside the cabin.
It seems the cable has somehow been disengaged, when I pull on the lever as there is no resistance .
The key hasn't opened the boot for many years so I just open it from inside the cabin. I think the lock was replaced many years back and no key came with it. It has opened flawlessly from inside the cabin.
What are my options for fixing this. All my tools are in the boot. :verymad: :verymad: :verymad: :verymad: . Of course so is my spare Tyre.
thanks in advance
thanks in advance
Just take out your backseat?
There will be a hole you can climb through to gain boot access.......and then you'll be able to sort out the problem.
But the mechanism which was pushed down needs to be moved into the up position. With the boot engaged in the locked position can I actually access that lever. I think the tongue from the boot lid prevents me from accessing it ?
Doesn't work in a 33 unless you can also shrink yourself.
I'd try with the key and see what that does. Or even try the key and the lever at the same time
Back seats taken out (see photo attachment), but its impossible to access due to opening size, rear battery on right and compartment location on left along with significant electrical wiring which would have to be disconnected.
Turns out the barrel did belong to the ignition key and a prolonged deep spray ,with a thin tube inserted ,of wd 40 eventually allowed the key to open the boot, though its not reliable, even after having sprayed. Reversed the boot switch and now will open only from inside the cabin .
Thanks all
Is the key or the key barrel tired? If its the key then Suggest you get the key code and get another key cut or you could be doing this all over again
Guest
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
    • Appreciate the insight! Talked to some local folks and they basically told me "it's not that deep." As long as the threading on the inside matches what's at the steering rack, everything else can be constructed-to-fit. There are full aftermarket kits I can use - probably better for my car overall since it's lowered.  Example: GKTech M14 Super Adjustable Inner Tie Rod Set - Nissan Skyline R32 R33 R33, 240SX, 300ZX, 350Z / Infiniti G35 M14I-TROD-2 gktM145-TROD gktM14I-TROD - Concept Z Performance (These can be packaged with their "high misalignment" tie rod ends).
