Hi guys i thought id post up a thread to educate not only my self but all members on here about inormative dailys, i always wondered what would be a great daily while the pride and joy awaits the weekends so i think this would be a great start, i would like to keep it simple and short with key point information so its easier to flick through and have a read. For example...
Make/year: 1992 nissan 180
Market value : $5000
Price per tank: $70
Ks per tank: 300km
Post away!!!!
https://www.sau.com.au/forums/topic/431531-post-up-your-dailys/
Make/year: 1999 Pulsar SSS
Market value: $3500-5000
Price per tank: $60-65 on 98
kms per tank: 500-550kms
Make/year: 2005 Hilux 2WD dual cab (manual)
Market value: who cares
Price per tank: $90-110 diesel
kms per tank: 750-830kms
Make/year: 2007 Hilux 4WD dual cab with fitout (auto)
kms per tank: 600-700kms
Make/Year: 2001 AU Falcon XR8 sedan
Market value: $7k
Fuel: $80 worth of 98
Range: 350-650km dependant of driving
Make/Year: 2006 BFII XR6 Turbo ute
Market value: $20k maybe??
Fuel: $100 full tank 98
Range: Used for towing so f**k all (350km) or bout 500km if not towing round town
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
