hey guys
i am almost track ready with my rb25 s13 build but i have a few issues that need sorting first.
the main problem is the engine isnt able to catch the falling rpm when coming off the throttle. the engine will idle all day but when i blip the throttle the rpm will increase then fall past the idle and the engine will stall.
what voltages should i be seeing coming from the brown and purple plugs for the AAC valve?
i have done all the wiring needed for the conversions and believe it could be electrical, if anyone else has an idea of where to look please tell.
https://www.sau.com.au/forums/topic/431541-rb25-wont-catch-falling-rpm/
my boost/vacuum guage shows around 24 in hg vac at idle and increases when I let off the throttle.
my bov is venting to amostphere and I read this causes problems however the bov came off my old rb25 r31 which didn't have the idle problem.
When i bought an aftermarket BOV that vented to atmosphere i got told to keep the standard one that vents back because if it doesnt then it will stall after getting off the throttle. So change the BOV to a recirculating one and see how you go.
shit ay, thanks for the input :)
the 31 was running a standard rb25 ecu which is why I kinda ruled out the bov being the problem. unfortunately ill have to weld a tag onto my intake pipe and tap a fitting in so I can recirculate the air.
before all of this iv
just got another question. what gives the signal to increase the rpm at idle when electircs start to get turned on like headlights/high beams and my electric cooling fans? at idle I can switch both fans on and the head lights and the idle will drop. I believe iv
missed something when wiring up all sensors.
  • 4 weeks later...
if anyone's interested, I have blocked off the bov with a coke can gasket and it's hasn't help much. I did however find that my tps was missing one the two bolts that get undone when adjusting the sensor.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
