What kind of punishment can you put the stock drivetrain through before upgrading? I have a R33 with an auto. My HP goal is 450-500. Motor is built for it and just recently installed it back into the car. Haven't started it yet cause waiting on a few more parts to come in the mail. I've been so wrapped up with other stuff that I just realized that I haven't touch the drivetrain. Wouldn't mind going to a manual but running out of time for this to debut at a show and sourcing parts here in the US is difficult. (car must be driven 600 miles to attend) Can the auto transmission, torque convertor, drive shaft, rear diff, etc handle this power? I've attached the vin plate for better insight. post-116132-13786745979762_thumb.jpg
The RB25DET gearbox can easily handle the power (really, the torque) levels you're talking about. But of course it is better to do it on one that is either new or freshened than to do it on one with worn selectors, synchros and all that jazz. The main components are big and heavy though, so they can certainly carry some mechanical load.
The diff is big and stron, the tailshaft and driveshafts are all strong. But the same things applies. Sloppy old CVs will always give before good condition ones will.
Word is that the stock bottom end of the RB blocks handle almost 1000hp. That's what I guess I'm asking. What kind of power the stock RB gearbox auto and manual would hold along with the rest of the drivetrain.... Has people snapped axles or C/V's?
Thanks! I was typing and didn't see this response yet.
Do they make new gearboxes? I was thinking on ordering a used one if I come back with the car and doing a refresh on it. I'd love to do a ratchet trans but putting that kind of money in a transmission is hard to ask for it back.
New RB25 boxes are available for about 3 grand here in Oz. Worst case you could order one from here, but I'm sure that Jap sourced or possibly US sourced alternatives should exist.
1000HP should not be attempted on RB blocks without a partial grout fill. They will do it, but they will end up splitting. Grout filling is cheap insurance if you're planning to go mental on power levels.
If you are planning to go that far, then you have a lot of reading to catch up on.
I don't recognize that term grout fill?
People snap axles at the drags with 700hp or less but Rips put over 1000hp through a stock front and rear end (but with a monster powerglide/transfer box)
Is that like installing thicker cylinder sleeves? If so, I understand that.
No - imagine taking out the frost plugs and pouring concrete in to the block until its half full.
Here ya go - apparently Yanks call it Hard Blok
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?storeId=10001&catalogId=10002&langId=-1&Ntk=all&Jnar=0&Ne=1%2B2%2B3%2B13%2B1147708&searchTerm=hardblok
There's quite a few options - e.g. OS Giken from Japan PPG dogbox from Aus Autosalon Yokohama from Japan and HKS dog box H pattern or sequential like this: http://www.trademe.co.nz/motors/car-parts-accessories/nissan/gearboxes/auction-635181453.htm
and more...
and more...
Yeah, look at the price tag. $15k isn't exactly cost efficient. Wouldn't mind spending $4k on a trans but not $15k. I couldn't ask $15k or more on an upgrade like that. There's a reasonable percentage you can ask for when selling your car when heavily modded. But I must admit, that HKS kit would be a dream to have.
Yes. I know that term. I steer far from that. Heat dissipation and heat soak become issues
No they don't. You don't have to fill the whole water gallery. 1/4 fill is sufficient to re-inforce the weak part of the block.
This is one of the reasons I said you have a lot of reading to catch up on.
I'm not going that route. No reason to have that much power in a Skyline. 500 is plenty. If i wanted more, I'd do a LS swap. Thanks for the info though. It's helpful. Just wondering about the drivetrain and its reliability.
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
