Hey i have taken my BOV off my car, and i was wondering what methods people use after they have done this.
I simply got a plate made up that screws over the outlet on the engine.
I know you can place the stock BOV back on, but i choose not to do this.
just wondering how everyone else did theres, just so i know if there is a different way then what i did.
https://www.sau.com.au/forums/topic/43157-bov-blocking/
Mate... I had no blow off valve at all. But i makes a funny noise of chopping air as the compressed air passes back over the impella. This not only puts pressure on the impeller but it makes the noise of a blow off valve anyways. The police were gonna write me a ticket for having a loud blow off valve and when i popped the bonnet and show them there was none. They told me to put a standard one on because they make very little noise. If i didnt then next time they will fine me....
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-881068
I took my BOV due to my readings about them. and my personal beliefs about them.
when running no BOV (not even a tock) .. you do get the flutter of the waste gate, this is why nissan placed a stock BOV on there cars to get rid of the sound.
the logic behind this is ...
the older people want a family car that doesnt drive around making pigion noises.
if any of that makes sense?
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-881104
Mic Sky - Well one of the houses (the fatter one) has a cap on the end
and the thinner one is currently cut right back with a bolt in the end of it.
I am going down to a few shops tomorrow and seeing if i can get a cap for the thinner hose.
if not im goilg to weld a little nipple/knob on to the flat custom cover so it just stays blocked and plugs in there .. just so it looks neater.
I will take a photo to explain what i mean when i get it done :)
heh .. sorry
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-881108
I was under the Impression that a bov was fitted to give the turbo longlivity, to reduce the back pressure over the impella which puts stress on the turbo, not so some old fart could drive in peace, if you where running the stock intake box then you wouldn't hear much sound with or without the stock bov....
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-881127
Good point...
However im unsure how much longlivity it would give wiht or with out a bov.
Not to sure how a plum back bov works, im a bit rusty on that knowledge ..
but wouldnt that be doing the same thing as runnign with no bov?
eg: putting the pressure/air back through the turbo?
i think i might go do some reading on this so ..
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-881131
Plumback = venting excess boosted air through the bov back into the turbo inlet pipe, a stock setup and a ' legal ' setup is plumback.
When you are running no bov you get chopping of the compressed air going back over the impella, think of it like this, if you run no bov exhaust gas is trying to push the turbine blade one dirrection, and the boosted air has nowhere to escape but back through the impella pushing its way back through it going the exact opposite direction as the air is supposed to be travelling thus putting stress in the turbo, exhaust gas pushing one way, excess boost pushing the other way, something has to fail unless the access air has somewhere to go when the throttle is closed.
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-881135
Good point...
not using a BOV will not only shorten the life of your Turbo but will also cause the turbo to slow down between throttle off's, hence making it feel laggy as the wheel needs to pick up speed again when you get back on to the loud peddle..
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-883185
lets see if i have this right, (sound/wankfactor aside)...anything ive missed?
Atmos BOV:
For:
1) keeps turbo happy
2) less gear change lag than all (with a/m computer)
3) doesnt insert hot (from compression) air back into intake
Against:
1) afm counts more air then really there - need aftermarket computer to stop rich gear changes
2) illegal (due to emissions, ie running rich on gear changes?, and/or noise pollution?)
Plumback BOV:
For:
2) less gear change lag than no bov?
3) doesnt mess up afm readings, wont make run any richer on gear changes
4) legal
Against:
1) inserts hot air into intake, (= slightly less power due to less air density)
No BOV
For:
1) more legal than atmos (may be illegal due to emissions on gear change?)
Either way:
1) mildly heats air into intake, not as much as plumback (from chopping + recompression of air that went back thru turbo)
Against:
1) turbo wont be happy due to chopping
2) gear change lag
3) counts air twice on gear change (= runs rich unless a/m computer?)
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-883427
Lol ill back up that avatar too :)
Ive found running now BOV has stopped my car from runnign rich.
im still investigating the pros and cons.
Every Bov leaks... find me one that 100% has no leaking ever and you can be my australian idol :)
so you loose power there.
In short the only happy solution its seems is to run a plumb back blow off valve.
any even if it put hot air though your turbo, unless you doing some serious racing, i feel this is really irrelevant.
I feel in the long run. if your running a stock turbo at stock boost any of these peoblems listed above are much of a nothing.
but thanks for the info guys. keeping me educated :)
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-883892
Hi when you have got two blow off valves like i have (R33GTS-T) a stock one and an aftermarket one is it at all posible to remove the stock bov,cover it over accordingly,plug up the recirculation holes in the intake pipe and have no problems with the cars performance whatsoever?or would it be better to just replace the pipe going over the motor all together???...........It is also my knowledge that if the bov doesnt retain the recirculation that it is fineable by the epa and the police all because of the oil mist that runs through the intake pipes being thrown out into the atmosphere with an externally venting bov.Much like the oil catch can enclosed (ok) externally vented (not ok)
https://www.sau.com.au/forums/topic/43157-bov-blocking/#findComment-885815
    • Sorry had a bit of a week and haven't had heaps of time to follow this, so apologies if I've missed something - any chance of showing a log with the rpm, turbo speed, MAP, and wgdc all in one view? Definitely an "interesting" problem, and while it's definitely worth noting that there was a similar issue with the twins I'd not completely put all bets on the root cause being the same thing.  Keep an open mind, follow the data.
    • I built this engine approximately 12 years ago so my own head (brain) is a little grey on the exact hardware in the RB head, however what I recall is. Stock RB25 NEO TURBO Intake Camshaft HKS 260 degree Exhaust Camshaft (R34 GTR) RB25 NEO Turbo Springs  I ported/removed the exhaust stud humps found in the RB25 head so theres less turbulence but it wasn't ported/polished properly, just a hump removal. I've attached two pictures of the before and after to illustrate.     The ECU gets its boost reference from the nipple on the rear of the head on the intake side, behind the fuel rail. The wastegate gets its boost reference from a nipple on the cooler pipe immediately after the comp cover.  Could a decent pressure drop across the intercooler cause the wastegate to be seeing a higher PSI than what the ECU is seeing, and thus it can't control it accurately and quick enough?   We ran a line to the actuator and watched it open and close using an air compressor, while we didn't have a gauge on the line to see when it was cracking open, it was opening smoothly.  I just removed the gate now and even though the documentation says you need to open it in a vice due to preload (which I did), there wasn't any preload on the cap, which is something we noticed straight out of the box as well when new. This silver cap internally is threaded to the actuator rod that runs out the bottom of the straightgate. Not sure how I'm supposed to get this spring out to be frank.. Potentially but everyone else doesn't appear to have to stop at 500kw because of 6boosts design.  I would, but I think I'm getting to that point where if I'm going to do the head and make another 100kw, then I'm going to need a fancy gearbox and quite a few other things and 10k becomes 20k becomes 30k within a few months. I'm not necessarily sold on the idea just yet that the head is restrictive at 4000rpm (and what.. 300kw?) and yet doesn't seem to be restrictive at 7000rpm when it's making 500kw, however I'm obviously not closing the door on that theory.
    • Yeah - Half the problem is I know this sensor actually goes to 150C.. I'm pretty certain it is min of 11C. So still more data required I suppose. It's really quite hard to get the oil temp to 100+ then immediately pull over and take a reading before the temp drops. Annoyingly I suppose the range I really 'want' is likely 80 -> 120C. TBH the ecu can't really *do* anything with it, and the gauge itself is very visible... ...but you know how it is.
    • My EFR 8474 Black, made 800awhp on a roller dyno. at 25-26psi. E85. Shaft speed was around 106,000rpm 1.01 rear. The rear is maxed.  6 boost Turbosmart 60mm gate 3.5inch exhaust  Head is worked to the shithouse. Bain racing. VCam. 272 exhaust. RB28 - RB26 foundation.  You have an intake issue. Start getting proper data and I mean go back to the simple things.  - Pressure test your intake - Block off the Turbo BOV, you don't need it.  - Test pressure before and after your intercooler If your head is pretty stock, that is your issue. Especially if it is NA.  Take it off and spend $10k on it.
    • Temp = -21.052 X Voltage + 114   That should get you pretty close. Calcs based on two points I could do easy calcs on (30 and 70 degrees).   It also says your sensor should only read as low as 9 degrees when it maxes out at 5V, and should hit a peak of 114 degrees at 0V... Just as a heads up if you were going really cold places, or wanting to be aware when temps really go up with it.
