bought a twin cam head and it seems to be missin some bolts
i need the four bolts that hold the timing plate on, or maybe some photos or discriptions of them.
also what are the bolts that hold the spark plug coil bit down in the head valley, photos would help alot.
should there be washers with the head bolts?
cheers
al.
https://www.sau.com.au/forums/topic/431594-i-need-some-nuts-and-bolts/
these are all the bolts i have. they all came in a bucket.
i need the four bolts that fit in were the rubber gromets are to bolt the timing plate to the head. i think 3 are m6 and one is m8.
i think this might be one, it has a bush atached to the washer to locate the timing plate?? but its the only one i have.
if that what they are im not sure i can just get some from the local bolt guy.
The old bucket of bolts, that's no fun when you didn't put them in there, and not much better if you put them in there :) Don't you have a wrecker nearby? They would charge you stuff all then you know they are definitely the right bolts.
Suggest you use Nissan FAST or website below to find out the correct partnumber and contact your local Nissan dealer, they should have most of it in stock as its commanly used across several models within Nissan.
http://www.netred.se/fakethinkpad/SPD/drawing.aspx?menuID=141
if some one could take the time to remove thier timing cover and remove a bolt and take a photo of it, so i can see what they look like. i might have them some where.
im in the country and import wreckers are a bit rare.
al
I'm having the same trouble, but i pulled the bolts out myself haha.
Any 10mm bolt should be fine, as long as the cover doesn't move when the bolts are in, if it does just throw a small flat washer behind them so they don't tighten up through the rubber and you should be fine and not have any timing belts snap in half.
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
