Hey guys,
So i made up a boost leak tester as per another thread I came across. Pod filter adapter, pvc end cap and air compressor tyre valve.
Worked great! I had 5 leaks I identified. At the beginning it wouldn't hold pressure for more than 1 second. Now raising it to 5 psi, it will hold for at least 15-20 seconds, slowly dropping off.
I can still hear 1 air leak. It's coming from down near the exhaust/back of the engine. I've checked all the hoses at the top and they seem to be ok, soapy water shows no bubbles.
My question is, is it normal for it to taper off boost within that time? Could the noise i'm hearing be the air coming from engine out into the dump pipe? Doesn't sound muffled, but it's the only thing I can think of.
Cheers
https://www.sau.com.au/forums/topic/431595-boost-leakpressure-tester/
I noticed I have air seeping up through the oil filler cap. I can hear the air hissing out from there. Its a nismo cap. Anyone know where I can buy the stock one? Also is that normal?
How do you get all th valves to be shut? Whats the most pressure you test with? Some people online say no more than 8psi but thats retarded since my turbo applies up to 20psi to the walls.
Ok i'll try that, i figured it might have been something like that.
I'm testing with 5-6psi, really no need to go anymore as you'll hear air hissing at that pressure. 5 psi is a lot of pressure.
My thinking was also, using this type of testing, your applying positive pressure to the "intake" side of the turbo, which normally is sucking. So that means the MAF and all that is seeing positive pressure. Which isn't a normal thing for it. I'd be weary about applying 20psi to it.
Edited by Shoujiki
Yeah that is true. When i'm pumping it up with 5psi, the intake hose is expanding! Quite funny to watch. Interestingly i had to reseal the MAF top with silicon as it was leaking too!
So i tried the gear/push thing, doesn't seem to change it. Same exact hiss, same area. How fast should the pressure drop off once it's at 5-6 psi?
Well this wont hold anything for more than say, 20-30 seconds now. It's a lot better now that i've gone through and found the other leaks. But this one is certainly letting air out.
The engine has a Greddy Profec 2 Spec B controller, i checked the solenoid connections and all seems good in that area. This hiss is coming from near the back of the motor, sort of where the boost pressure sensor is, but it doesn't seem to be that.
Bong testing costs coin, why would he need it now all the leaks are taken care of?
The small leak you have is no issue, if it is holding 5 psi for 20-30 seconds it is fine. Don't be scared to pump a little more in, I run 40psi in mine when testing, but I don't have the dodgy stock intake pipe like yours does Shoujiki.
I agree with Scott, I'd say it's probably not an issue. What you could try though, is pumping some more pressure in there. I found that at 5psi things were generally ok, but at about 12-13psi I found a couple of vacuum hoses that were leaking from t-pieces etc. Now I generally try to get my system to its target boost pressure, which is 20psi. Just watch your pvc end cap doesn't come shooting out and crack you in the hand, mine often does :P
Thanks guys for your help. Yeah smoke test seems a bit much at this stage, i don't really want to spend as such (hence me making up this great idea, thanks Hanaldo for your thread btw!).
I'll try a bit more pressure and go from there. If i really can' find it today then i'll just leave it and see how it goes. I'm curious to see how it will drive now with all these little leaks fixed. My target boost pressure is 11psi so i may try to get to that.
Yeah Scotty i think that dodgy stock pipe would explode at that pressure! It will be great to get that changed out to an alloy one. And yes i'll watch the end cap, it was that hard to get in there in the first place, and i used a hose clamp too, so hopefully it's nice and tight!
Again, thanks guys. :)
I spun up a proper alloy plug with a step so the hose clamp doesn't pop off, the hose runs to a gauge and trigger setup. I can tell you, at 40psi there is not much chance of sealing all the leaks, unless you glued them perhaps. Most would say it's overkill to pump that much in, but I run nearly 3 bar at gearchange.
If you are worried about the AFM, take it out of the equation, why would you run it in the system anyway? Just remove the afm/airbox, stick the bung in, and pressurize.
Yeah Scotty i think that dodgy stock pipe would explode at that pressure! :)
You would be surprised, I have shoved over 20psi into one without issue. They expand quite a bit. If it fails just hit me up for an 80mm alloy intake. :P
Ok so i found the "air leak". It seems to be coming from the valve cover? I have an oil weep back there somewhere, so perhaps it's coming out of that area? If I take the oil cap off, all the pressure releases straight away. Would having a weep like that really affect the car? I guess the pressure has to go somewhere.
Took it for a quick drive and boy what a difference. It actually boosts to 0.92bar now, never done that before. And the boost ramp is so strong, really kicks you back. Also no misfire at idle with an open filter like I had before.
Now that I think of it, because i'm pressuring part of the intake that never sees boost (ie pre turbo inlet side), i wonder if theres a hose/line connection somewhere there that's going off to the intake/valve cover area, like crankcase breather. So in normal boosting/driving conditions, there would be no boost in the valve cover area.
Edit:
Just had a look. That is indeed what the noise is. On the stock intake rubber pipe, there's 2 ports coming off it. One goes to the crankcase breather on the valve cover. The other goes to the turbo recirculation valve. So normally that pipe would never see boost pressure like that, as both ports are pre turbo, just after the MAF. I bet if i took off the hose on the breather and blocked it off, it would hold pressure.
Edited by Shoujiki
In fact, pushing air in through the BOV connection (one of the ports) should do nothing and pushing it in through the cam breathers should overcome leakage past the rings - now that I think about it.
You could try taking the turbo inlet off completely and use a dedicated bit of 3" (or whatever size to suit your turbo) hose to connect up with. That will cut those two connections out of the loop, but will cause you other hassles (disassembly being a big one, and possibly having to block off the BOV being another).
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
