  • 2 months later...
I have made a boost leak tester and plan on seeing if there is any leaks. And to avoid killing myself with compressed air or doing damage to my automobile, Can someone give me a run down on how to safely do this, where to put what? thank you.
Its quite simple really, take off your intake pipe and stick the fitting on the end on the end of the turbo and turn on your air compressor and listen for leaks. In regards to pressure I usually test with around 40psi to know that it will definately not leak at what I run which is 20 although had accidently done it at 90psi once and still had no leaks.
Gave it a try didn't get any pressure...?! Using a 12v tyre compressor, How long would these take to build the pressure needed? Should I just let it go longer
I attached the BoostLeakTester to the pipe after the AFM, which goes to the turbo inlet. Is this ok? Do I have to go directly on the turbo inlet?
I have tried with a 12v pump and it's pointless unless your system is already really well sealed. You really need a compressor or if you dont mind the hassle drive to a servo use their air pump find leaks then take back home and fix
I've read a heavy duty 12v compressor is fine, I was thinking that I will remove the intake pipe, Did everyone else remove the whole pipe to turbo
don't believe everything you read.
If you can hear a leak and can't find it, check the dipstick.
Any more than 5-10psi is overkill. As long as it holds pressure and doesn't drop straight away, be happy.
http://www.turboboostleaktesters.com/servlet/StoreFront
I did my test with with the "tester" attached to the AFM inlet, i.e. using the stock rubber inlet pipe. It doesn't split, or leak. Keep in mind that doing it this way means that you fill the cam covers with pressure too (as the crankcase vent goes to the inlet tube). So any leaks in that area (not normally pressurized like this) will show up.
A 12V compressor will be fine. The voltage the compressor runs on has nothing to do with it. If it can fill a car tire with air, it can pump 15-20 PSI into the intake. Albeit, maybe a bit slower than a "big" compressor that can run at 100-120 PSI (like mine does).
If your getting no pressure build up at all (even 1 PSI?) then you have a leak. Find it, fix it, and test again until the system can hold pressure for a reasonable amount of time.
^ EDIT: Having the oil filter cap off will bleed out all the pressure, as your using the stock inlet pipe pressurized, so all the pressure will bleed out the crankcase vent hose, and out the oil filler cap. When mine was pressurized, when i took the filler cap off, it made a nice woosh sound and the pressure went to 0.
Edited by Shoujiki
Interesting. Maybe the oil filler cap off was my problem, And not giving the 12v compressor long enough to build the pressure. I will give it another go tomorrow through stock inlet pipe. (stock inlet pipe looks a bitch to remove)
Edited by dyl33
You will need a compressor with a fairly large air reciever if you have any leaks worth repairing. 20psi should be fine.
This was my point. Had some major leaks that were too large for the little 12v pump to be able to show up because it couldnt get any pressure in there. Hooked up to compressor and they became apparent very quickly
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
