Picked up a set of front and rear 33 GTR brembos to be fitted to my r34 GT.
Any insight on those who have done it ?
Fronts seem to be a straight bolt up, but are the brake lines the same ? ATM I'm running 32 GTST calipers.
And for the rear, how is the handbrake set up ?
Cheers fellas
https://www.sau.com.au/forums/topic/431599-r33-brembo-conversion/
They use the same bolts, so that's no worries. What I'm concerned about is the rear handbrake setup ? How is it done on skylines ? All previous cars I've had have had a line that runs down and sits on a hook on the back of the caliper. Looking at the back of the brembos, it only has the brake fluid line. I haven't pulled the rear calipers off to look yet, will be doing it tomorrow, just getting insight first.
No, that's the point. The earlier Skylines all use 12mm bolts to mount the caliper to the upright. The R34GTT changed to 14mm bolts. The question was whether the R34 GT was the same as the GTT or the same as the earlier cars.
As to your handbrake question. I'm not sure what you mean. The handbrake is an internal drum, activated by cable. There is no hydraulic connection pertinent to the handbrake. The handbrake is nothing to do with the calipers.
It would be fair to guess that Nissan saw no point in making dedicated handbrakes for the Brembo cars. So the internal drum size should be the same for all of them. Having said that, I'm talking about one type of car at a time. So, if we were talking about putting R32 GTR Brembos onto an R32 GTR that originally had Sumitomos, you'd assume no trouble. Same if you were doing the same on an R33. But when you start mixing up earlier model GTR Brembos onto later model non-turbo cars, the potential exists for the existing brakes on your car to be made up out of bits and pieces that are sufficiently different from the turbo cars that assumptions start to break down.
34 GTT came with 2 pot rear and separate handbrake which will be plug and play for brembo conversion
If your rear are not 2 pot and just a single pot (like an s15), highly likely that you will need a handbrake conversion from any of the Nissan family as they all fit the brembo conversion
And you will also need the BMC from r33gtr/r34gtr/z33, otherwise it will be too rear bias
ATM I have the stock r34 single pot rear calipers, and r32 GTST caslipers on the front with adapters running 324mm GTR rotors. It brakes really really well, but it is too much on the front compares to the rear, it's not well balanced at all. I'll update this later and see how I go.
It's a question of fluid volume that needs to be moved. Bigger piston area means more fluid needs to be moved in order to obtain pad movement followed by pressure. A small master cylinder piston diameter means you use up a lot of pedal travel getting the pads to move onto the disc, then the hydraulic ratio is not very great and you need a lot of pedal pressure to put sufficient pressure onto the back of the pads.
I don't know what size MC piston is in your car, but it is a fair bet that it is smaller than the BM50 or BM57 size MCs that the Brembos' original car had.
Sure you've bled them properly? I put GTT and then 8 pot D2s on my Stagea and they worked fine although with a little more travel. I think the Stagea had a BM50 but I have since put a BM57 on to shorten the travel a bit. I would be surprised if you had no brakes at all. Try another bleed. But maybe if your car has a really small MC that could be the problem. I take it you are planning to upgrade the MC anyway - you are looking for an R34 GTR one or possibly a 300z DETT one. Also a bigger MC means you have to stand on the pedal harder so maybe try and get the booster to go with it if it is bigger then the one you have now.
I bled front and rear for almost an hour trying to get a pedal feel, then nothing. Put it down and went to drive, and I still had no brakes at all. Anyway, I sold the brakes last night, got double what I paid for them. I may just go the R34 GTT brakes front and rear with braided lines and call it quits there. After all I am only wanting 300 rwkw when boosted. Cheers guys for all the insight.
When I put the Brembos on my car, I had the same problem. Kept bleeding it and it did improve a bit. Put a Cusco BMC and that improved pedal travel noticeably. At the moment I can drive around with more confidence than the old stockers (pads were below average), but under hard braking the pedal starts to sink.
I need a new brake master :(.
I first put GTT brakes (with braided lines, a M/C stopper and Motul RBF600 brake fluid) and they were fine on my 1800kg Stagea. Only went with the D2s because a set came up and to provide insurance when hammering the car on the track. They should be fine on your car but maybe look out for a bigger M/C as well.
How did that setup go ? Because that's what I'm looking Into. ATM the front GTR rotors with 32 4 pots its pretty good. I just picked up the 34 2 pot rears last night. Was planning on the MC stopper and braided lines also.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
