Hoping someone has stumbled across this before.
I have an R34 skyline gtt with the previous generation power fc and an aftermarket wideband sensor.
Sometimes on warm starts (say water > 50 deg) the afr is 0.2 to 0.5 (or more) leaner under vaccum.
It doesn't happen all the time, most of the time it follows what's in the fuel map.
Sometimes it can be replicated at idle by letting car warm up, turn off, wait, start up again.
When left running for a while you can see it randomly lean, then return to fuel map value, or stay in a leaner mode of operation.
It's like a random vacuum leak, frustrating to tune.
What I know:
wot unaffected
o2 closed loop disabled, but oem o2 sensor connected
good battery 14.4v (through datalogit)
sensor check ok
stock bov
no air temp sensor on this model power fc
swapped z32 maf with another and no different
water temp correction is 1.000 at 80 deg, so afr should be the fuel map value
ignition timing unchanged at idle, even when running lean
injector duty unchanged at idle, even when running lean
fuel pump voltage unchanged at idle, even when running lean
can't be a dodgy wideband o2 sensor as engine note is audibly different when lean at idle
disconnected fuel purge canister loom (since its the only solenoid I can see), no difference
tightened all the intake clamps and turbo nuts, no difference
Going to check:
source another wideband o2 sensor (check just in case)
disconnect oem o2 sensor (shouldn't be doing anything but you never know)
measure fuel pressure
check vacuum leaks
disconnect idle stepper
check spark plugs
I'm thinking its a bug in the power fc logic.
I have had this issue for a few years and blamed hot fuel at track days, but in garage at home I can replicate and the fuel ain't hot.
Ideas welcomed.
My car does this. Also a power fc. Most of the times idle is fine then randomly it will idle leaner to the point it pops. I cant understand wtf is going in. I cant recreate the scenario. Ive tested for leaks etc and come clean.
When it happens the only other thing I noticed is there is less vacuum. According to my profc b when its running fine its at -96 but when it decides to play around its at -87. Ive also noticed the timing starts jumping to 16 then back to 15. Idle does not change but the sound of the car will and it pops.
Just spent a couple of hours trying to reproduce with extra gauges and can't make it happen atm.
I target 14.8 afr at idle, cell 2,2, 15 deg timing.
From logs (going back to 2008) at idle there are differences when it decides to go lean:
normal 14.9 afr, ends up being around 15.5 afr, sometimes > 16 afr
injector duty is up from 0.9 to 1.1 %
air flow voltage is up from 1100 to 1200 mv
vacuum is down from -520 to -500 mmhg
rpm is up from 750 to 800 rpm
timing remains at 15 deg, water temp > 60 deg
Seems to be directly heat related, car left a while, then warm start.
Two things from yesterday's diagnostics which I need more data on to rule out.
I unplugged the idle stepper connector and afrs appeared to be stable.
When I reconnected the connector and power fc went into some recalibration mode.
I found a small nick on one of the fuel pressure reg hoses and replaced the hose (I'd say from dyno operators).
However, I could maintain a vacuum on this pipe so don't believe the nick penetrated.
Anyhow putting car back together as I have a hill climb this weekend.
Will update this topic if I discover anything.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
