Need this gone
Delivery: 5 days by EMS
Garrett GT3576
Really rare Twin Scroll T3 AR.75 turbine housing
Garrett GT3576 T3 TS AR.75
Compressor Size: 6 blade 53mm/76.2mm
Turbine size: 68mm/60mm
Compressor flow: 55lbs/min (max 500-550hp)
100% Genuine
Journal bearing (not ball bearing!) Rebuildable. Barely noticeable spool difference when wideopen throttle compared to bb. ~300rpm max
Oil cooled centre core with 360degree thrust bearing
Capable of 450-550hp
Price: AUD950 Delivered to your door
Pay via paypal
PM me for details
Open to reasonable offers
Edited by robots
That turbo is over AUD1100 original price!
Brand new, never installed, original packaging all bla bla bla.
Come and take it !
Firm AUD850 delivered till Monday 16 September. Then goes to ebay.
Edited by robots
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
