hey people just wondering how I would go about reinstalling a turbo on my r33 gts-t as i assume the previous owner removed the turbo due to high performance laws. i'm still on my p's at the moment myself but possibly looking to get bits and pieces for when i'm on my full licence, trying to make it legal or as close to legal as possible. n00b question but what parts ect, would i need? appreciate all the help/advice i can get
https://www.sau.com.au/forums/topic/431658-reinstalling-turbo-on-r33-gts-t/
Are you sure they just pulled off the turbo? A Turbo engine with no turbo would be crazy slow due to the lower comp. Also, I didnt think it was actually legal to take the turbo off and drive it as they still consider it a turbo car?
Anyways, first step is check the car ever had a turbo on it.
To check whether its a factory turbo the easiest and most simple way is to answer these two questions:
1. Is the GT badge on the front quarter panels RED OR BLUE? Red = GTST ~ Blue = GTS
2. Is your car 4 stud or 5 stud? 5 = GTST ~ 4 = GTS
People change the hubs but almost never change the badges.
If the turbo was removed the car will run like crap and be awfully, dreadfully slow.
ALSO, the car is still ILLEGAL to drive on your p plates as its still a TURBOCHARGED car. Just because a turbocharger is removed doesnt make it legal. Its still a factory turbo, and is registered as such. Getting caught = fine, loss of liscence. Crashing = VOIDED insurance.
Nothing you do will make the car legal for a P Plater. Find turbocharged bits, reinstall. Sell car or keep until off your p's.
Edited by Bennis
LOL @ these threads. I wonder if these are all just kids with N/A 'lines, trying to figure out how to boost them without seeming dodgy, but in the process, looking like a dumbass.
You need one of these bruh:
gallery_50342_21087_1775674884ac58d5b4ec
There's so many of these threads already, do a search, you'll avoid the embarrassment.
it's definitely a gts-t, 5 stud ect
and #@colourclassic no harm in asking, if you don't have anything productive to say don't say it
Edited by optimusgrime
The 25det has 9:1 CR
That is not low compression by any means and whilst (obviously) slower than being turbo charged it WILL be fine until optimusgrime can bolt the turbo gear back on it
This is not 1986 when turbo sohc rb had 7:8 to 1 CR
That's a good point! I must have been flashing back to my vl turbo days :)
Non intercooled rb30et. . With low comp
Wouldnt have been overly nice to drive off boost im sure
Engines/fuel sure have come a long way since then
Edited by StevenCJR31
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
