Sorry in advance if this has been covered but the post I did find had already been deleted..
I have a HKS SSQ and the sound is dreadful and illegal.. It sits on the cooler pipe just after my intercooler (Drivers side) obviously trying to hide it from Mr. Policeman.
Question is, am I able to plumb the HKS BOV back?
I don't think I can..
I also have a brand new Kompact Turbosmart BOV & an RB20det BOV w/ stock crossover pipe.
But I can't just put the Kompact one on because I cannot close my bonnet.
So should I remove my cooler pipe going into the plenum? And put the original crossover pipe with the stock BOV.
Or find somewhere to put this Kompact one in?
Because it needs to be close to the MAF, right?
Cheers guys.
https://www.sau.com.au/forums/topic/431679-plumbing-back-atmo-bovs/
The BOV should be physically located close to the throttle body and should return just before the turbo (after the AFM, and pointing towards the turbo and away from the AFM). So the stock location is the best location for achieving the first part of that, but realistically it can be located anywhere on the post turbo piping if you are desperate to find a spot for it.
The logic for placing it close to the TB is that the air only ever has to move towards the engine. If you locate it well away from the TB, then when the BOV vents, the air between the BOV and the TB has to reverse direction before it can flow out the BOV, which causes some people some concern (and I can understand why).
cheers
Yes the SSQV can be plumbed back. The front cover is removeable and people fit an outlet into it which permits plumb back. Although where its mounted at the moment is very far from where you want to plumb back to, I would suggest throwing a stock piece back in there. I run a stock piece with 20psi, no worries.
Yeah, think I might just go back to stock and hopefully won't need any different cooler pipes.
The stock RB20 BOV is very easy to press in compared to the Kompact one I have..
Might just be the spring dying from old age I guess.
Thanks guys, pretty much cleared this up for me.
Delete if need be, mods. :)
Maybe it doesn't really achieve anything, but I bash to top of the stock bovs in with a hammer and a socket a little bit to add preload to the spring. Haven't had any issues with leaks and it doesn't cost anything, and in the stock location noone can see you took to it with a hammer!
I have seen bovs either side of the I/c and even some (oem) on the intercooler. I am planning to relocate mine to the turbo side so that there is just a short pipe for the return to the turbo inlet. The job of the bov is to relieve the pressure on the turbo and most of the air being expelled will come from the turbo after the throttle is shut. The air between the bov and the throttle does not all have to be expelled.
And yes there is a stock part for the HKS bov to accommodate a return pipe... in fact there is a number of alternative pipe sizes...e.g. http://www.ebay.com/itm/HKS-Blow-Off-Valve-BOV-SSQV-outlet-1-Recirculation-Adapter-/320965078546?pt=Motors_Car_Truck_Parts_Accessories&hash=item4abb026e12&vxp=mtr
cheers
You dont need to bash it. When on boost theres 12 or what ever boodt you're running coming through the silicone hose on your bov pushing down on it to help keep it shut. So as long you've got some spring pressure she'll be fine.
  • Like 1
The air between the bov and the throttle does not all have to be expelled.tr
You cannot relieve the pressure just to one side of the BOV without relieving the pressure throughout the whole IC pipe length. If the BOV is a long way from the TB, then air that was previously flowing towards the TB does in fact have to turn around and flow the other way in order to decrease the pressure in the tract. You cannot decrease the pressure without letting the air out. To argue otherwise is simply wrong.
There is a reason that Nissan and other OEMs put them where they do. Why do you think Nissan would go to the effort of that stupid plastic return pipe arrangement under the front of the engine bay on GTRs when they could have just put the BOVs on the hot pipe? It may not be the single most important reason to do anything involved with BOVs, but it is a valid reason.
Tell that to the guys that have had bovs leaking :)
Mine is plumbed from just after the turbo, Its probably not ideal but I havent had any problems
That pic helped. That is your AFM with red & yellow plug? Yes.
Also my wastegate (external) has NO pipe at all, just the wastegate blowing straight onto my turbo oil line.. I don't like that :/
Is it as easy as making up a pipe and bending it back into the exhaust?
Yes it is that easy.....except that you have to be able to bolt it all together once it is welded up. So a little thought during the "design" phase can save you a lot of swearing later. Main point of interest are the bolts/nuts holding the dump flange to the turbine housing outlet.
  • Like 1
"air that was previously flowing towards the TB does in fact have to turn around and flow the other way in order to decrease the pressure in the tract."
I put it forward, there's no need for the air to reverse and flow the other way. Consider this - throttle shuts, airflow into engine stops as throttle plate has now blocked path. Compressor still spinning and pumping air into piping which is now not flowing. BOV located straight after compressor on intercooler piping lets this air out rather than pressure building and pushing against compressor. So the airflow would be effectively stopped, pressure remains the same, and any incoming air would continue to flow the same way, just be diverted straight out the BOV rather than continuing through towards the engine. Get back on throttle and more boost pressure is already there as it hadn't been depressurised in front of throttle plate.
To be honest i think the difference between putting it just before throttle, or just after compressor, would be sweet F.A, in most cases, but it makes sense to me to put it in front of compressor. For another reason, when no longer being driven by the turbine (under closed throttle) the compressor will slow down alot more trying to drive air through the intercooler rather than allowing it to vent out straight away before passing through the I/C.
Obviously this is based on zero hours of research and development by me :P and I'm sure auto manufacturers might have given it at least a few hours testing.....
  • Like 1
Who's got some pics of their BOV's and where they are plumbed back? :)
Would be easier in my case to fit it just after the compressor, because when I shut my boot there is hardly ANY room...
Probably cause its been whacked in the front end.
This chassis damage affects a lot, I am slowly learning :/
Edited by ZRBE
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
